WBT-0730.01 Topline Gold Plated 24k Binding post (Set x4)
These WBT-0730.01 Binding post from the Topline series feature a high-end design. They feature 24K gold plating for optimum conductivity and resistance to corrosion and oxidation. In addition, the two-piece clamping system ensures high contact pressure.
Reference : 9572
249,00 €tax incl.
207,50 € tax excl.
Shipping date: 22-04-2025.
WBT-0730.01 ToplineGold-Plated 24k Binding Post (Set x4)
Photo of WBT-0730.01 Toplinebinding posts
These WBT-0730.01 Binding post from the Topline series feature a high-end design. They feature 24K gold plating for optimum conductivity and resistance to corrosion and oxidation. In addition, the two-piece clamping system ensures high contact pressure. Overall, the WBT-0730.01's design offers mechanical stability and optimum signal transmission.
Terminal blocks can be screwed or soldered internally, with conductor cross-sections up to 10mm² (AWG7), while they accept 4mm banana plugs, 6-8mm forks, as well as bare tinned cables up to 6mm² for external connection.
The integrated retaining mechanism (WBT patent) holds the banana plug firmly in place when the front locking nut is tightened, and thus not only protects the connection from accidental disconnection, but also ensures extremely high contact pressure.
WBT-0730.01 Topline binding posts highlights:
  • 24K gold-plated copper
  • High-performance clamping system and retaining mechanism
  • Choice of welding or screw connection
  • Max. current-carrying capacity : 70A
  • Machined from solid
  • Suitable for forks 6 - 8mm, banana 4mm and bare wires up to 6mm²
  • Accept cables up to 10mm² (AWG7) for internal connection
  • Internal connection for soldering or crimping with Torx T.6 screws
  • Eddy-current-free
Product typeBinding post
Conductor materialCopper alloy
Conductors plating24k gold plating
CompatibilityBanana plugs 4mm
6-8mm forks
Bare, tinned cables up to 6 mm²
Internal connexionTo screw / To weld (Torx T.6 screws)
Max. cable diameter5.3mm
Max. pannel thickness10mm
Mounting hole diameter11.4mm
Identification ring
Total dimensionsØ15.8 x 51.4mm
Weight36g/Binding post
PackageSet x4
ColorGold
Mounting typeTo screw
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)10.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
WBT-0730.01 Topline Gold plated 24k Binding post (Set x4)
These WBT-0730.01 Binding post from the Topline series feature a high-end design. They feature 24K gold plating for optimum conductivity and...
