WBT-0735 Speaker Terminals (Set x4)
WBT-0735 speaker terminals are 24k gold-plated and polished for maximum resistance to corrosion and oxidation. They meet the most demanding signal transmission requirements, thanks to a meticulous overall design.
By buying this product you get 25 loyalty points
Reference : 2304
259,00 €tax incl.
215,83 € tax excl.
Shipping date: 20-03-2025.
WBT-0735 Borniers Speaker Terminals Makrolon Insulated 24k Gold-Plated (Set x4)
Photo of WBT-0735 speaker terminal
WBT-0735 speaker terminals are 24k gold-plated and polished for maximum resistance to corrosion and oxidation. They meet the most demanding signal transmission requirements, thanks to a meticulous overall design. In fact, they provide a high-pressure contact level and feature full Makrolon insulation. In addition to providing the most effective insulation, Makrolon is a plastic with excellent impact resistance, making WBT-0735 speaker terminals extremely durable. All these features enable them to accept large cable cross-sections while maintaining excellent conductivity. An integrated clamping system protects the banana plugs from accidental disconnection. Puzzle plates (mounting insulators) complete the package for simplified installation. WBT's Safety Line series is designed for the discerning hobbyist or professional.
If you are using WBT-0735s for bi-wiring and wish to combine them with WBT-0725 short-circuit bridges, the terminal blocks must be mounted separately, i.e. without the connecting tab. Make sure to maintain a minimum distance of 30 mm (terminal center to terminal center). The distance to the second pair of terminal blocks must be exactly 60 mm.
Zoom in on a WBT-0735 binding post
Product typeSpeaker terminal
ConceptionMonobloc
Contact materialCopper alloy 68%
Contact plating24k gold
InsulationMakrolon
CompatibilityBanana plugs 4mm
6 or 8mm spades
Bare crimped wire
Max. conductor cross-sectionExternal: 6mm² (9 AWG)
Internal: 10mm² (AWG 7)
Internal connectionCrimping or welding
Max. panel thicknessFrom 0.5 to 10mm
Identification ring2x red
2x white
Gross weight208g
Package4x WBT-0735 speaker terminals
Mounting typeTo weld
Mounting typeTo screw
Mounting typeTo crimp
ConnecticFemale
Max panel thickness (mm)10.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
WBT-0735 Speaker Terminals Makrolon Insulated 24k Gold-Plated (Set x4)
WBT-0735 speaker terminals are 24k gold-plated and polished for maximum resistance to corrosion and oxidation. They meet the most demanding signal...
