XANGSANE XS-6001AU LONG Speaker Terminals
Xangsane's XS-6001AU LONG speaker terminals are ideal for mounting on enclosures and/or loudspeakers with wall thicknesses from 2mm to 18mm maximum. They feature non-slip seals. Connector contacts are made of gold-plated copper alloy for enhanced conductivity and resistance to corrosion and oxidation.
Reference : 18461
22,90 €tax incl.
19,08 € tax excl.
Shipping date: 18-02-2025.
XANGSANE XS-6001AU long
Speaker Terminals Gold-plated (Set x4)
XANGSANE XS-6001AU LONG Speaker Terminals Gold-plated (Set x4)
Xangsane's XS-6001AU LONG speaker terminals are ideal for mounting on enclosures and/or loudspeakers with wall thicknesses from 2mm to 18mm maximum. They feature non-slip seals. Connector contacts are made of gold-plated copper alloy for enhanced conductivity and resistance to corrosion and oxidation. The internal cable is mounted without soldering, using a hexagon socket screw. On the other side, these connectors accept forks and banana plugs.
Product typeSpeaker terminals
Contact materialCopper alloy
Contacts platingGold
Min. mounting panel thickness2mm
Max. mounting panel thickness18mm
Drilling diameter12mm
Screw thread for mountingØ8mm
Compatible connectorsForks (Ø6/8mm)
Bananas (Ø4mm)
Internal cable assemblyScrew-in (hexagon socket screw)
Marking rings
Total dimensions67 x Ø14mm
Package1x Set of 4 Xangsane XS-6001AU LONG speaker terminals
Mounting typeTo screw
ConnecticFemale
Max panel thickness (mm)18.0
Accepts Banana PlugsYes
ConnectorBanana / Spade
XANGSANE XS-6001AU LONG Speaker Terminals Gold-Plated (Set x4)
Xangsane's XS-6001AU LONG speaker terminals are ideal for mounting on enclosures and/or loudspeakers with wall...
