XANGSANE XS-6001AU SHORT Speaker Terminals Gold-Plated (Set x4)
Xangsane's XS-6001AU SHORT speaker terminals are ideal for mounting on enclosures and/or loudspeakers with wall thicknesses from 2mm to 4mm maximum. They feature non-slip seals. Connector contacts are made of gold-plated pure copper for enhanced conductivity and resistance to corrosion and oxidation.
Reference : 18460
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 18-02-2025.
Speaker Terminals Gold-plated (Set x4)
XANGSANE XS-6001AU SHORT Borniers Haut-Parleur Cuivre Pur Plaqués Or (Set x4)
Xangsane's XS-6001AU SHORT speaker terminals are ideal for mounting on enclosures and/or loudspeakers with wall thicknesses from 2mm to 4mm maximum. They feature non-slip seals. Connector contacts are made of gold-plated copper alloy for enhanced conductivity and resistance to corrosion and oxidation. The internal cable is mounted without soldering, using a hexagon socket screw. On the other side, these connectors accept forks and banana plugs.
Product typeSpeaker terminals
Contact materialCopper alloy
Contacts platingGold
Min. mounting panel thickness2mm
Max. mounting panel thickness4mm
Drilling diameter12mm
Screw thread for mountingØ8mm
Compatible connectorsSpades (Ø6/8mm)
Bananas (Ø4mm)
Internal cable assemblyScrew-in (hexagon socket screw)
Marking rings
Total dimensions51 x Ø14mm
Package1x Set of 4 Xangsane XS-6001AU SHORT speaker terminals
Mounting typeTo screw
ConnecticFemale
Max panel thickness (mm)4.0
Accepts Banana PlugsYes
ConnectorBanana / Spade
2 reviews
Mauvais choix - Très déçu !
Très déçu par ce produit, la partie filetée arrière présente un jeu boulon/écrou trop important, l'écrou ne se serre pas car il saute du filetage, inutilisable. J'ai donc modifié les borniers pour les fixer différemment et en les usinant (taraudage), je constate qu'ils sont en laiton et non en cuivre. C'est la première fois que je suis déçu avec un produit vendu par Audiophonics... je changerai ces borniers par des vrais "cuivre" plus tard. Dommage !
This review has been posted for XANGSANE XS-6001AU SHORT Speaker Terminals Gold-Plated (Set x4)
Très belle qualité.
Je commence à connaitre la marque, je la teste par curiosité et ces borniers sont indécents. En main ils sont lourds, le reflet noir bleuté est juste magnifique, mais surtout (ce dont j'avais besoin) la connexion avec les fiches banane se fait dans son intégralité et fermement, donc un contact optimal. Très facile à monter car le pas de vis de montage peut accepter des câbles de 4mm +, parfait pour recabler le cross over de mes enceintes avec les mêmes câbles que j'utilise pour les alimenter. Je verrai à l'écoute s'il y a amélioration, mais en tout cas le but pour moi était d'avoir une bon contact avec des viborg banane de 3.8mm. Esthétiquement le contrat est rempli et à 20 euros les 4, c'est offert. Je vous les conseille fortement.
Xangsane's XS-6001AU SHORT speaker terminals are ideal for mounting on enclosures and/or loudspeakers with wall thicknesses...
