Yarbo BP-006RP Rhodium plated terminal blocks (pair)
Reference : 3150
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 22-04-2025.
Yarbo BP-006RP Rhodium-plated binding post sold by pair
bornier rhodium audiophonics
This high quality high quality contact loudspeaker terminal binding post block with carbon ring clamp benefits from high machining precision, competing with the best European and American productions. Offering the possibility of connections by tightening the internal cable with two screws, it allows to completely eliminate the need for welding.
This loudspeaker terminal block offers a highly efficient clamping ring mechanism for any quality banana connector.
For the screwable part of the connector, click on this link: 2.0mm hexagonal Allen key.
Characteristics
PlatingHigh quality Rhodium
Maximum  inner cable diameter5.2 mm
Maximum external cable diameter5.5 mm
Required drilling diameter9.5 mm
Minimum panel thickness2 mm
Maximum panel thickness23 mm
Total length71 mm
affordable rhodium binding post
best sale rhodium binding post
terminal block loudspeaker soldering screw
Mounting typeTo screw
ConnecticFemale
Max panel thickness (mm)23.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
