AUDIOPHONICS I-SABRE DAC - The different generations of DAC for Raspberry Pi
Posté le 2018-03-14 Tutorials & Guides, Tutos 15562
schema button isabre
Although optimized to work with the script available in the forum, power management works by default in hardware mode without having to modify the audio solution retained.
Here is a schematic diagram of connecting from one terminal to another to "shunter" the microcontroller. It is therefore necessary to remove the AT Tiny85 microcontroller from the circuit as indicated.
In this case it will be necessary to use a switch (permanent contact) to keep the Raspberry Pi on.
DAC V3 Schematics
I SABRE V3
DIFFERENCE OLED SCREEN CONNECTION
SABRE V3 GEN 1 GEN 2 GEN3
AUDIOPHONICS I SABRE V3 GEN 3
Connection SABRE V3 GENERATION 1 straight wiring pine pin
schéma sabre V3 generation 1
Connection SABRE V3 GENERATION 2 WITH IR Ribbon 2 is reversed
Sabre V3 GEN2
schéma sabre V3 generation 2
Connection SABRE V3 GENERATION 3 straight wiring pin pin and remote IR
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
