ROON / RaspTouch - Web Controller Setup
Posté le 2018-12-21 Tutorials & Guides, Tutos 10094
Roon logo
Here is a quick tutorial to connect ROON to a RASPTOUCH using the ROON + Web Controller Dietpi image.
The Web controller provides graphical feedback and ROON control from the Rasptouch screen.
Although this interface is more basic and limited than the ROON interface, it allows you to manage the progress of the volume and the display of the covers directly on the reader.
It is also possible to access ROON's librairy, but the ergonomy is less advanced than the ROON client.
Once the RASPTOUCH is equipped with the ROON + Web Controller image and started, it will try to connect to your ROON application.
In order for it to connect, it is necessary to allow the connection of the Web controller in ROON.
For that we have to go to the options, in the section Extensions.
You should have in the extensions the "Roon Extension Manager"
Click Settings
Select Web / Connectivity, Web Controller, and then Action -> Install
Roon web controller Install
Then go back to "Roon Extension Manager" and select Web controller, then Start
Roon Web Controller Start
Once installed you should have the Webcontroller in the list of extensions:
Roon Web controller Installed
It will be enough to activate it by clicking on Enable:
Roon Web controller Started
At this point the RASPTOUCH GUI should start, and display the sound cards that are enabled in your ROON application.
If you have not activated the Rasptouch sound card in ROON, it happens in Settings -> Audio -> Networked where the Rasptouch should appear.
Roon Web Controller Interface
Roon Web Controller Library
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
