Lecteur réseau Opensource : Solutions
The Raspberry Pi is a microcomputer that can fulfill the function of a network drive thanks to the help of several available audio distributions. These are Open Source, that means their code is open and anyone can make improvements or changes. Each has its specificities, depending on the basic technology its uses modules and third-party software that are grafted to it.
Among those available we list here the most complete and used to create a network drive:
Diet Pi
Diet Pi is a very open distribution allowing many applications to be installed through a menu. It requires knowing how to connect to an SSH terminal to be able to administer it. It is not initially made for audio, but it allows the installation of software used in a network drive such as Logitech Media Server / Squeezelite and Roon Bridge. Using LMS opens up many possibilities through plugins like Qobuz, Deezer, Spotify, Tidal, Airplay, DLNA ...
Moode Audio
Moode Audio is a distribution based on MPD, default linux software for playing audio streams and files. Its interface allow use without connecting to a terminal and can read local, network or Internet radio files. It also enables third-party protocols like Airplay, DLNA, and Spotify Connect to be enabled.
PiCorePlayer
PiCorePlayer is a complete distribution based around Logitech Media Server / Squeezelite, with a simplified interface allowing you to make all the necessary settings. It is very light, and has the Jive Lite interface to control LMS on a touch screen. Using LMS opens up many possibilities through plugins like Qobuz, Deezer, Spotify, Tidal, Airplay, DLNA ...
RoPieee
Roopie is a distribution based on RoonBridge, allowing you to play all the content available in your ROON server on the Raspberry Pi. The XL version adds software to vary the sources with Airplay, DLNA and a Squeezelite deck.
Volumio
Volumio is an easy to use distribution, allowing connection to most protocols available on network drive. Reading local, network and Internet radio files is very easy. It has a DLNA browser to read from a DLNA server (NAS for example) without prior indexing. It also allows you to play Airplay, DLNA, Roon and Squeezelite streams. With a subscription, gives access to the integrated navigation of your Qobuz and Tidal account.
Nous avons essayé de récapituler dans un tableau comparatif les différentes fonctionnalités de chaque distribution pour Raspberry pi :
Specification / DistributionMoode AudioVolumioPicorePlayerDiet PiRoPieee
Moteur de lecture principalMPDMPDLMS / SqueezeliteLMS / SqueezeliteRoonBridge
Additionnal RendererDLNAVersion XL
AirplayVersion XL
Roon *RoonBridge
Spotify ConnectVersion XL
SqueezeliteVersion XL
Serveur DLNA
Lecteur de fichiers audioLecture de fichiers locaux (périphérique USB)Auto MountAuto MountVia l'interfaceVia SSHVia serveur Roon
Accès fichiers réseau DLNAAvec indexationAccès dynamiqueAccès dynamiqueAccès dynamique
Accès partage réseau (Windows, NAS...)
Integrated Music ServicesQobuz**
Spotify
Deezer
Tidal**
Apple Music
Amazon Music
Interface graphiqueHTTP + HDMIHTTP + HDMI + App SqueezeliteHTTP + App SqueezeliteRoon + HDMI
Play from ApplicationRoon *AirPlayRoonBridge / AirPlayAirPlayRoonBridge / AirPlay
SpotifySpotify connectSpotify connect
Bubble UPNP
(Qobuz & Tidal)
DLNA
QobuzAirplay (on iOS)
TidalAirplay (on iOS)
Apple MusicAirplay (on iOS)
Amazon MusicAirplay (on iOS)
* Requires subscription
20 Commentaires
Laisser un commentaire
  • Philippe Ayzac
    Philippe Ayzac 2024-02-20
    Bonjour, J'ai installé la version moode 8.2.4 sur mon EVO SABRE il y a quelques mois avec l'image evo_sabre_oled_moode-r824-arm64. Moode marche bien mais je ne peux pas accéder à moode:4150 (probleme idem avec l'IP).
    Avez-vous une astuce ?
    Merci
    • Audiophonics Team
      Audiophonics Team 2024-02-21
      Bonjour, l'interface sur le port 4150 a été retirée depuis que moOde intègre nativement shellinabox qui remplit toutes ses fonctions de façon beaucoup plus puissante. Pouvez-vous me détailler ce que vous cherchez à faire?
  • Thomas Vergnolle
    Thomas Vergnolle 2024-01-18
    Bonjour. Le plugin quobuz semble ne plus fonctionner sous dietpi. Comment faire pour mettre à jour LSM? Ou est-ce une autre démarche? Merci?
    • Audiophonics Team
      Audiophonics Team 2024-01-29
      Bonjour,
      Si vous utilisez un Evo Sabre nous avons une image piCorePlayer avec un LMS à jour.
      • Pierre Bommel
        Pierre Bommel 2025-01-02
        Je pense que cette solution ne fonctionne plus, hélas...
  • Jean-Christophe URBAIN
    Jean-Christophe URBAIN 2023-08-24
    Bonjour,
    J'ai un raspDac LTE de 2000 et je n'ai encore jamais mis Moode Audio à jour. Je voulais savoir s'il éait possible de le faire et comment ? Merci d'avance !
    • Audiophonics Team
      Audiophonics Team 2023-09-12
      Bonjour, je vous conseille d\'installer une image neuve depuis le site de moOde audio. Reconfigurez la sortie audio depuis les options systèmes puis réinstallez le gestionnaire d\'alimentation pour que le bouton en façade soit pris en charge à partir de ces instructions : https://github.com/audiophonics/Raspberry-pwr-management/tree/moode_dev.
        Jean-Christophe URBAIN 2023-09-18
        Est-ce que je perds toute ma configuration initiale ? (médiathèque, radios...)
        • Audiophonics Team
          Audiophonics Team 2023-09-19
          Il est très probable que la configuration soit perdue (sauf si vous partez d'une version de moOde relativement récente). La version 7 a introduit une fonction d'import / export de la configuration mais d'expérience ça ne fonctionne pas toujours très bien d'une version à l'autre. Une solution est de faire l'installation sur une seconde carte SD pour revenir en arrière facilement ou pour avoir une référence pour réecrire la configuration du nouveau système.
  • jerome Lecanteur
    jerome Lecanteur 2023-04-29
    Bonjour,
    J’ai un Evo Sabre Dac avec MoodeAudio sur le Pi .
    Tout fonctionne très bien, sauf qu’on est obligé d’attendre vos updates pour monter de version.
    Serait il possible que vous fournissiez un mode install via package ou archive pour intégrer les afficheurs LCd et autres fonctions propres à ce dac.
    Ceci nous permettrait d’être plus à jour sur le release de Moode, et plus souple sur des config que l’on pourrait modifier dans avoir peur de tout casser et de devoir réinstaller la SD depuis zéro.
    Merci d’avance pour votre réponse.
    J
    • Audiophonics Team
      Audiophonics Team 2023-05-02
      Bonjour,
      tout le software propre au EVO Sabre est disponible ici : https://github.com/audiophonics/Evo_Sabre
  • christian cheignon
    christian cheignon 2023-03-11
    Bonjour
    Je viens de mettre en place le clavier virtuel sur mon rasptouch à l'aide de votre tuto.
    https://github.com/audiophonics/rasptouch_volumio3/blob/main/readme.fr.md
    C'est fonctionnel, mais en qwerty.
    Le bouton de paramètre ne semble pas fonctionnel et je cherche le moyen de mettre ce clavier en AZERTY.
    Comment puis je faire ?
    Merci d'avance
    Christian
    • Audiophonics Team
      Audiophonics Team 2023-03-13
      Pour être honnête, tant que Volumio n'aura pas de véritable plugin clavier virtuel fonctionnel, je n'aurai que des solutions un peu cache-misère pour ce type de problème.
      Je vous propose d'essayer cette commande (en SSH) :
      cp /home/volumio/chrome-virtual-keyboard-master/layouts/keyboard_fr.html /home/volumio/chrome-virtual-keyboard-master/layouts/keyboard_en.html
      Cela écrase simplement le template du clavier américain par celui du clavier français.
      Songez à relancer le service volumio-kiosk après cette commande ('systemctl restart volumio-kiosk') ou un reboot.
        christian cheignon 2023-03-15
        Bonjour
        Dans le message précédent qui n'est pas publié, j'ai fait une erreur en vous informant que vous n'aviez pas mis le plugin audiophonic ON OFF.
        En retournant sur le tuto je viens de voir que ce n'est pas le cas.
        Désolé, j'avais parcouru le tuto trop rapidement
        Cordialement
        Christian
        Bonjour
        Merci ça marche super.
        Pour infos dans votre tuto https://github.com/audiophonics/rasptouch_volumio3/blob/main/readme.fr.md, vous avez oublié de mettre votre plugin Audiophonic ON OFF, qui fonctionne très bien.
        Christian
  • jerome Lecanteur
    jerome Lecanteur 2022-04-11
    Hello Audiophonics Team ,
    Quel est la fréquence de mise a niveau de vos distributions custom moodeaudio/volumio ou autres ?
    Par ex moodeaudio que j'utilise, est fourni en 7.6, mais la version 8 est deja la .
    Ou seriez vous prêt à fournir les sources de vos motifs/scripts, ou un script d'install, voir un package ?
    Merci pour votre retour.
    Jerome
    • Audiophonics Team
      Audiophonics Team 2022-04-28
      Bonjour,
      Et bien malheureusement cela dépend des distributions, de la fréquence des mises à jours et de la complexité du produit.
      Je documente mes sources aussi souvent que possible mais il existe encore pas mal de trous.
      Avez-vous un produit spécifique en tête ?
  • Baptiste Le Sueur
    Baptiste Le Sueur 2021-10-10
    Bonjour,
    Très intéressant, je suis en plein dedans. Manque à mon avis la comparaison sur la prise en charge d'une interface par écran tactile.
    B
    • Audiophonics Team
      Audiophonics Team 2021-10-11
      Bonjour,
      moOde est sans doute le plus simple à mettre en place en terme d'interface graphique puisqu'il est livré avec un chromium-browser activable depuis l'interface web. Il suffit donc généralement de renseigner les spécificités de l'écran dans /boot/config.txt pour obtenir un système fonctionnel.
      Volumio propose un plugin similaire ( touch display ). Idem il fonctionne avec un chromium-browser qu'il faut cette fois télécharger depuis l'interface des plugins (~10-15 minutes selon votre connexion internet et votre système + /boot/userconfig.txt ). Personnellement, je trouve aussi que l'interface Volumio a le meilleur "feeling" en terme de réactivité lorsqu'on utilise un écran tactile.
      Les autres distributions peuvent tourner avec jivelite mais je trouve (personnellement) ce dernier terriblement compliqué à mettre en place en dehors de l'écran officiel raspberry.
      Allo propose également une version de DietPi avec une micro interface : https://dietpi.com/phpbb/viewtopic.php?t=2317 cela doit sûrement permettre d'y relier un écran tactile pour peu qu'on soit un peu à l'aise avec l'invocation et manipulation d'un serveur graphique.
  • Jean Chassin
    Jean Chassin 2021-04-23
    Hi, I am using Raspdac mini with Linn Openhome multiroom solution which is working very well and is compliant with my Linn installed base. I am using Kazoo app to control it.
    I shared my source here : https://github.com/jchassin/ohPlayer
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
