Configure gain, bypass and LED on Audiophonics Purifi and NCoreX amplifiers
Posté le 2023-04-06 par Audiophonics Tutorials & Guides, Tutos 12955
Configurer le gain, bypass et la LED sur les amplificateurs Audiophonics Purifi / Ncore
Some of our Audiophonics power amplifiers based on Purifi, NCore or NCoreX modules are controlled by an interface board (driver) specially developed by us. This provides you with a number of settings: 4-level gain adjustment, the option of activating or deactivating the buffer and management of the LED on the front of the device (for some).
These settings are directly accessible via a series of jumpers and DIP switches under the device. We detail here all the available settings and the associated jumpers and DIP switch positions.
Réglage du gain, buffer et LED sur amplificateur Audiophonics NCore / Purifi
Gain setting
The driver module integrated in these amplifiers has a gain level adjustment. This one allows to select a gain value among 4 available. These values are different depending on whether you have an amplifier based on a Purifi or NCoreX architecture.
Purifi
The amplifier is by default set to a gain of 26dB. The setting is made with a DIP switch on the bottom of the unit. The other available values are the following:
Réglage du gain sur amplificateur Audiophonics Purifi
Depending on the selected gain level, the input sensitivity needed of the source signal varies to reach the maximum power of the amplifier:
GainInput sensitivity needed for max power
20dB4.19Vrms
26dB2.07Vrms
32dB1.05Vrms
34dB0.83Vrms
NCoreX
The amplifier is by default set to a gain of 25dB. The setting is made with a DIP switch on the bottom of the unit. The other available values are the following:
Réglage du gain sur amplificateur Audiophonics NCore / NCoreX
19dB5.33Vrms
25dB2.67Vrms
31dB1.5Vrms
33dB1.2Vrms
Enable / disable the buffer
Our Purifi and NCoreX amplifiers include a preamp section called buffer with variable gain shown above, it is activated by default.
However, it is possible to bypass it using the Bypass jumper. In this case the XLR or RCA input is directly connected to the amplifier module.
The overall gain will then be equal to the nominal value of the module, approximately 12.5dB (11.5dB for the HPA-S600NCX).
This configuration is to be used with a powerful preamplifier, capable of driving a 2-4kohm load with 10Vrms.
This adjustment is made using a jumper under the device.
Réglage du Buffer sur amplificateur Audiophonics Purifi / NCore
Enable / disable the LED on the front panel
Each of our Audiophonics Purifi and NCoreX amplifiers has an ON/OFF button with an LED on the front panel. This one is activated by default but it is possible to turn it off thanks to a jumper under the amplifier.
Réglage de la LED sur amplificateur Audiophonics Purifi / NCore
Audiophonics Purifi AP300-M400ET not concerned.
36 Commentaires
Laisser un commentaire
  • Boyan Boev
    Boyan Boev 2024-08-19
    Hello, I have Audiophonics Purifi LPA-S400ET. Can it be bridged?
    • Audiophonics Team
      Audiophonics Team 2024-08-19
      Hi,
      No such amp are not brigeable.
      We remain at your disposal.
  • József Kovács
    József Kovács 2024-08-07
    I bought an AUDIOPHONICS HPA-S500ET with the Purifi 1ET7040SA -s on board
    From this you had not sold the Sparkos Edition, but I planning upgrade mine with Sparkos OPAs & PDUs
    Are these the right things to buy? :
    2 pcs of SPARKOS LABS SS3602 Dual Discrete OPA DIP8 (Unit)
    2 pcs of SPARKOS LABS SS7815 Discrete Voltage Regulator +15V
    2 pcs of SPARKOS LABS SS7915 Discrete Voltage Regulator -15V
    If not then please correct me in your answers.
    If I understand right they do not need soldering. But the pictures let not to see sockets.
    Can you please show some detailed close up picture how PDUs able to exchange!
    • Audiophonics Team
      Audiophonics Team 2024-08-08
      Hello,
      The OPAs can be changed without soldering but it will be necessary for the change of regulators (note that this operation will make you lose the warranty of the device).
      • József Kovács
        József Kovács 2024-08-08
        Is that possible to get a board all the Sparkos installed by you and send the original back to you?
        • Audiophonics Team
          Hi,
          Unfortunately no, but OPA can easily be swaped without any soldering involved
  • Sebastien DENIS
    Sebastien DENIS 2024-07-19
    Bonjour, ayant le LPA S400 ET, est-ce que se dernier pourrait alimenter facilement des Focal Aria 936 ? cordialement.
    • Sebastien DENIS
      Sebastien DENIS 2024-08-05
      RE-bonjour, y'a t'il un réglage gain à effectuer en cas de nouvelles enceintes ou il faut juste se fier à la sortie pre-out du préampli ? j'ai un denon avc x3800h et donc j'avais régler sur 32db sur le LPA ? mes enceintes étaient des focal chorus 726v le son était parfait mais avec mes aria 936 le son n'est plus le meme ça manque de peche ?! je l'ai mis au max soit 34db mais je ne vois aucunes amélioration voir moin bien
      cordialement,
      • Audiophonics Team
        Bonjour,
        Ce sera un peu léger pour ce modèle mais devrait parfaitement suffire à obtenir un niveau d'écoute confortable sans pour autant vous permettre de disposer de la puissance maximale des enceintes. il n'est pas nécessaire de toucher au gain lors d'un changement d'enceintes.
        • Sebastien DENIS
          Sebastien DENIS 2024-08-31
          Excusez moi pour la réponse tardive, quel type d'ampli proposeriez-vous pour alimenter parfaitement les focal aria 936 ? cordialement
          • Audiophonics Team
            Audiophonics Team 2024-09-11
            Bonjour,
            Vos enceintes nécessitent 300W / 8 pour délivrer leur puissance maximale.
            Pour une écoute à niveau confortable les bases Purifi LPA et HPA 400 sont suffisantes (vous aurez approx 200W ), si vous désirez pouvoir en tirer le maximum absolu il existe des modèles plus puissants reprenant toutes leur qualités ex : https://www.audiophonics.fr/fr/recherche?search_query=purifi+750ET
    • Audiophonics Team
      Audiophonics Team 2024-07-22
      Bonjour, Oui sans l'ombre d'un doute.
      Il est largement assez puissant pour les piloter sans souffrir et en leur offrant punch et dynamique (y compris à bas volume).
      • Sebastien DENIS
        Sebastien DENIS 2024-07-22
        Merci , sachant quels sont apparemment assez difficile à driver c'est une bonne nouvelle
  • Sébastien DELPIERRE
    Sébastien DELPIERRE 2024-07-02
    Bonjour, je possède un amplificateur de puissance HPA S400ET. Je souhaite l'upgrader avec des AOP SPARKOS SS3601 AOP Discret Simple DIP8 ou SPARKOS LABS SS3601 AOP Discret Simple DIP8 (Unité).
    Est ce que cette opération est possible à faire de manière aisée ? Est ce qu'il y a un réglage de tension à faire ? Quelle différence entre un sparkos simple ou double ? quel est le modele que vous conseillez ?
    merci pour vos réponses.
    cordialement
    • Audiophonics Team
      Audiophonics Team 2024-07-03
      Bonjour,
      Vous ne pourrez utiliser que la version double de cet AOP (SS3602) et oui le changement n'implique aucune soudure ou autre réglages.
      Cela consiste simplement à remplacer ceux d’origine par ces discrets en respectant uniquement le bon sens d'insertion.
  • david harnett
    david harnett 2024-05-12
    Is the preamp section/buffer enough to use this directly with a dac streamer with digital volume control and no seperate preamp?
    Thanks
    • Audiophonics Team
      Audiophonics Team 2024-05-22
      Hi,
      yes, the buffer has been made to be able to deliver maximum power with unbalanced level output (+/- 2Vrms).
  • Tonny Hooijer
    Tonny Hooijer 2024-01-30
    Hello , i'm using Audiophonics Purifi HPA-S400ET with topping dx9 as pre-amp . Am i correct as the topping dx9 signal in low gain can go up to 12vpp i could bypass the buffer entirely?
    • Audiophonics Team
      Audiophonics Team 2024-01-31
      Hi,
      Yes with such output level you can bypass the gain buffer.
      • Tonny Hooijer
        Tonny Hooijer 2024-02-01
        Thank you i tried it , and yes i had enough volume ...but the sound was not as good as with buffer.
        More laid back even and muddier lows... i set buffer to lowest gain . The sound is fantastic of this amp now. The build quality is awesome... Love it!
  • Luis Ignacio Rojas Godina
    Luis Ignacio Rojas Godina 2024-01-18
    Bonjour, je viens d'acheter un amplificateur HPA-S400ET et j'en suis complètement amoureux, il sonne bien mieux que je ne le pensais. Merci Audiophonics. J'ai une petite question : quelle est le réglage correct pour connecter le nouveau DAC Topping D90 III à mon amplificateur via XLR ? J'utilise une paire de Kefs R3, accord parfait avec le HPA-S400ET
    • Audiophonics Team
      Audiophonics Team 2024-01-29
      Bonjour,
      Son niveau de sortie normal est ligne (4Vrms) ce qui correspond à un réglage de gain de 20dB : https://www.audiophonics.fr/fr/blog-diy-audio/41-configurer-le-gain-bypass-et-la-led-sur-les-amplificateurs-audiophonics-purifi-et-ncorex.html
  • Philippe BRAY
    Philippe BRAY 2023-09-07
    Bonjour,
    Je comprends la carte driver réglable sur 4 niveaux de sensibilité, mais pas sûr de saisir la fonction spécifique du buffer et du by-pass.
    La génération précédente proposait, si j'ai bonne mémoire, 2 niveaux de sensibilité et la possibilité de by-passer la carte d'entrée pour attaquer directement le module ampli - est-ce la même chose, ou en quoi est-ce différent ?
    Merci !
    • Audiophonics Team
      Audiophonics Team 2023-09-12
      C'est la même chose, mais avec 4 niveaux de gain. Le "buffer" est la partie préampli de cette carte, dont le gain est réglable.
      Il est aussi possible de la contourner totalement, pour attaquer directement le module d'ampli avec un préampli externe.
      Dans ce cas on dit qu'on le bypass.
  • József Kovács
    József Kovács 2023-08-29
    Hello
    I have a DAC-9 form Nuprime and it has RCA 4V and XLR 8V-s max output if I buy an LPA or HPA-S400ET how I should set the DIPs and jumpers for that.
    This DAC can drive difficult AMPs I had LINN LK2 on it with an input impedance of 5000. I needed to be careful not to saturate that amp.
    How it would be with the Purify ?
    Many thanks for your answer.
    • Audiophonics Team
      Hi,
      The level is not high enough to be able to use the Bypass mode, configuration 1 is gonna be the best choice : https://www.audiophonics.fr/fr/blog-diy-audio/36-configurer-gain-bypass-sur-module-amplificateur-purifi.html
      Best regards
  • Dan Berilloux
    Dan Berilloux 2023-08-07
    Bonjour la team, j'ai extremement hate de recevoir ce HPA 600 NCX, mon premier class D après du tube !!
    Je vais l'associer à un Streamer/DAC EMERSON de chez Wattson, et probablement bientot au Madison (pour la qualité de son preamp et le le potentiometre de volume ... plus safe que via l'application mobile). :)
    Que pensez vous de l'association de manière generale, compte tenu de la tension de sortie (respectivement 2V en RCA et 4.2V en XLR)?
    des conseils concernant les reglages Gain et Buffer ?
    Je suis sur des enceintes à rendement superieur à 100db/w/m
    Merci pour vos conseils !
    • Audiophonics Team
      Audiophonics Team 2023-08-07
      Bonjour, et merci de l'intérêt que vous portez à nos produits.
      Il existe beaucoup mieux dans cette tranche tarifaire mais cela fonctionnera parfaitement.
      Ces appareils asymétriques ne vous permettent pas de sortir du réglage de gain par défaut (maximum).
      N'hésitez pas à contacter notre support technique pour toutes questions supplémentaires.
      En vous remerciant par avance.
      Cordialement
      • Dan Berilloux
        Dan Berilloux 2023-08-16
        Bonjour merci pour votre réponse mais soit ca ne répond pas soit je n’ai pas compris ;)
        J’ai bien les jumpers pour choisir un des 4 niveaux de gain…. Je demandais lequel sera le plus adapté compte tenu de la tension de sortie du dac 4.2v.
        Et je ne comprends pas non plus ce que fait le Buffer on/off ?
        • Audiophonics Team
          Bonjour,
          Avec ce niveau de sortie le réglage idéal est la configuration 1 (20db) : https://www.audiophonics.fr/fr/blog-diy-audio/41-configurer-le-gain-bypass-et-la-led-sur-les-amplificateurs-audiophonics-purifi-et-ncorex.html
          Désactiver le Buffer coupera tout réglage de gain.
          Cordialement
  • Axel Endriss
    Axel Endriss 2023-08-05
    And I'm wondering whether also the older models have jumpers to adjust the settings for buffer/bypass and front LED? The description is btw not fully conlcusive: e.g. default setting for Buffer is 1-2 connected plus Bypass is 2-3 connected = Buffer activ. But how to set the jumpers to Bypass?
    Apart from this I like to use the chance to praise this amplifier. It really sounds very good :-)
    Best regards Axel
    • Audiophonics Team
      Audiophonics Team 2023-09-04
      Hi,
      Yes older models also have gain settings ( accessible only by opening the device) but not led on / off possibility.
      Best regards
  • Axel Endriss
    Hello,
    due to that it's new that the jumpers are accessable under the device I would appreciate if you would offer here also the description for the older models were the jumpers are inside, perhaps together with the information starting from when this changed.
    Best regards Axel
    • Audiophonics Team
      Here are the settings for the previous gen :
      https://www.audiophonics.fr/en/blog-diy-audio/36-set-gain-bypass-on-purifi-amplifier-module.html
      Best regards
  • Jean-Philippe Roi
    Jean-Philippe Roi 2023-05-15
    Bonjour. Quel réglage de gain me conseillerez-vous avec l'association Ncorex hpa s600 et un dac advance dx1 utilisé en tant que préampli. Ces derniers seront utilisés en mode symétrique XLR et le dac a des niveaux et impédances de sortie de 4v/10kΩ? Je suppose également que je dois ne pas mettre en mode bypass le buffer?!
    Cordialement.
    • Audiophonics Team
      Audiophonics Team 2023-05-16
      Bonjour,
      Merci pour votre intérêt pour nos produits.
      Avec l'association Ncorex hpa s600 et un dac advance dx1 utilisé en tant que préampli, nous vous conseillons de choisir le gain bas sur les amplificateurs. En effet, le DAC advance dx1 a une sortie symétrique de 4V qui est suffisante pour alimenter les amplificateurs sans risque de saturation ou de distorsion. Le gain bas vous permettra également de bénéficier d'une meilleure dynamique et d'un meilleur rapport signal/bruit.
      Nous vous recommandons également en effet de ne pas mettre en mode bypass le buffer de l'amplificateur.
      Nous espérons que ces informations vous seront utiles. N'hésitez pas à nous recontacter si vous avez d'autres questions.
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Next
