November 2023 : The selection of the month by Audiophonics
Posté le 2023-12-05 News, Monthly selection 1683
xxx
November 2023
Discover Audiophonics' HiFi selection of the month, featuring the catalog's new highlights:  Audiophonics AP300-M400ET, Eversolo Amp-F2, FiiO BR13, Ibasso DC06PRO, MiniDSP Flex HTx and Audio-Technica ATH-WP900.
The Audiophonics AP300-M400ET is a mono Class D power amplifier assembled in our workshops in France. Based on a PURIFI 1ET400A module andHypex SMPS600N400 power supply module, it features a mono RCA and XLR input selectable via a bipolar selector, and delivers power up to 400W @ 4Ω on its HP terminals.
669,00€ TTC (557,50€ HT)
Eversolo AMP-F2
The AMP-F2 from Eversolo has been developed in collaboration with Starke sound. It's a bridgeable Class D power amplifier delivering up to 2x 250 @ 4Ω or 1x 450W @ 2Ω. Very powerful, it is based on an NS600 amplifier module and a 600W switching power supply. In terms of connectors, the essentials are there, with RCA and XLR inputs and speaker terminals on the outputs. It's the ideal companion for a DMP-A6 or DMP-A8 streamer, or a DAC-Z8 or DAC-Z6.
799,00€ TTC (665,83€ HT)
Eversolo AMP-F2
FiiO BR13
Fiio's BR13 Bluetooth receiver is a compact device featuring a Qualcomm QCC5125 Bluetooth 5.1 receiver chip, an ES9018K2M DAC chip and a TPA1882 amplifier chip. It features a wide range of connectors, and accepts high-resolution Bluetooth codecs (AAC, SBC, aptX, aptX LL, aptX Adaptive, aptX HD, LDAC) as well as 24-bit 96kHz resolution streams via its inputs. Its RCA output is capable of reproducing a signal level of 2Vrms.
69,90€ TTC (57,50€ HT)
FiiO BR13
EVERSOLO DMP-A8
Ibasso DC06PRO
Ibasso DC06PRO
The Ibasso DC06PRO is a compact, portable DAC/headphone amplifier featuring one ES9219C DAC chip per channel, plus FGPA. It supports up to PCM 32bit 384kHz, DSD256 and MQA 16x. Input is via USB-C and two outputs are available: 3.5mm jack and 4.4mm balanced jack.
115,00€ TTC (95,83€ HT)
MiniDSP Flex HTx
MiniDSP Flex HTx
Big brother of the Flex HT, the MiniDSP Flex HTx is a 2x8-channel multichannel audio processor (DSP) perfect for integration into a home theater or multichannel sound system. It features 2 x 8 analog inputs/outputs (RCA and TRS 6.35mm balanced jack) as well as numerous digital inputs, including an HDMI ARC/eARC input.
1449,00€ TTC (1207,50€ HT)
The Audio-Technica ATH-WP900 high-fidelity headphones are closed dynamic circum-aural headphones with two Ø53mm transducers and flamed maple shells. Its 100dB sensitivity and 38 Ohm impedance make it easily compatible with a wide range of Hi-Fi equipment. It features a very wide frequency response (5Hz-50kHz) for rich, detailed sound reproduction.
649,00€ TTC (540,83€ HT)
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
