WiiM Pro test by Hans Beekhuyzen
Posté le 2023-12-13 Tests & reviews, HiFi Tests 15681
WiiMPro Picture
Read Hans Beekhuyzen's review of the WiiM Pro network player. This streamer from WiiM is an extremely compact and versatile Hi-Fi device. Bit-perfect, it turns any conventional audio system into a connected one, thanks to its WiFi and Bluetooth 5.1 connectivity. This streamer also supports Apple Airplay and DLNA wireless transmission protocols, and includes a Chromecast. Featuring audiophile components such as a Burr Brown PCM5121 DAC chip supporting high-resolution streams up to PCM 32bit 384kHz, it will open the doors to the world of streaming whether you use Spotify, Deezer, Tidal, Qobuz or Amazon Music. Versatile and multi-functional, it can be used to set up a multi-room system, works with voice assistants and can be controlled via the free WiiM Home app featuring a 10-band equalizer.
See the Wiim Pro product sheet
WiiM Pro picture
WiiM Pro
Audio Streamer Bit-Perfect WiFi AirPlay 2 DLNA Chromecast Multiroom Bluetooth 5.1 24bit 192kHz
Key points of the Wiim Pro test by Hans Beekhuyzen
Extensive connectivity for easy integration into a complete audio system
The WiiM Pro acts as a gateway between your various sources and a DAC or amplifier. The WiiM Pro's optical inputs also allow you to connect your TV or video game console to enjoy a sound experience via your audio system. It can be controlled from an app on your smartphone or via a remote control (sold separately) to make the Wiim Pro user experience even more comfortable.
Example of a Hi-Fi installation with WiiM Pro
Overview of WiiM Pro front and rear panels
On the front of the WiiM Pro, there are 4 pictograms for touch control:
  • Volume -
  • Play/Pause
  • Preset selection
  • Volume +
Presets can be configured via the smartphone control application, giving you direct access to your favorite playlist or online radio station, for example.
On the rear of the WiiM Pro, you'll find a full range of connectors, including an analog RCA input, an optical Toslink input and an RJ45 Ethernet port. Outputs include a coaxial SPDIF output, a Toslink optical output and an analog RCA output. Not forgetting the 12V trigger on the 2.5mm jack, the built-in microphone for control via voice assistant and the USB-C power connector.
Inside the WiiM Pro
The WiiM Pro is made up of three separate PCBs, corresponding to the digital processing circuit, the analog processing circuit and a PCB for the touch-sensitive buttons on the front panel. A closer look reveals an Everest ES7243 analog-to-digital conversion chip (192kHz ADC), as well as a TI Burr Brown PCM5121 DAC chip, a Realtek ethernet interface chip and a 4-core Amlogic microprocessor with 4Gb RAM, enabling it to deliver high-quality sound reproduction whatever the audio source.
Inseide the WiiM Pro
A pleasant, efficient control app
The WiiM Home control app is compatible with iOS and Android smartphones and tablets. Once installed, it gives you access to every conceivable music source, whether via your computer, your local NAS server or a variety of online streaming and radio services.
WiiM Home App
Audio test: WiiM Pro performance
For his test of the WiiM Pro, Hans Beekhuyzen used three configurations to test the device's limits. Overall, in his opinion, the WiiM Pro is an excellent network player for its price, with a fine stereo image and good low-frequency resolution. However, despite its high quality, the WiiM Pro can reach certain limits if used with a very high-end audio system. In conclusion, Hans simply states that the WiiM Pro sounds much better than its price would suggest. It achieves the performance of some much more expensive units, while being highly versatile and easy to integrate into a Hi-Fi system.
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
