DA-S250NC Review by Audio Science Review
Posté le 2023-12-19 Tests & reviews, HiFi Tests 3261
Photo of DAC DA-S250NC
Discover Audio Science Review's test of the Audiophonics DA-S250NC integrated amplifier. The DA-S250NC is a versatile, high-performance amplifier with a high power reserve of 2x 250W @ 4 ohm, featuring an ESS Technology ES9038Q2M DAC chip, a wide range of connectors and precise volume control. This power reserve is made possible by the Hypex Ncore NC252MP Class D amplifier module. In addition, the ES9038Q2M DAC chip supports high-resolution streams up to PCM 32bit 768kHz and native DSD up to DSD256. Its versatile connectivity includes numerous digital inputs, Bluetooth 5.0, speaker terminals and an RCA output for setting up a 2.1-channel system with active subwoofer, or for connecting another integrated amplifier. In terms of design, the DA-S250NC stands out thanks to its large acrylic panel covering the front panel and an OLED screen for information display and menu navigation. The amplifier is of course accompanied by a remote control for convenient and easy remote control.
The complete Audiophonics DA-S250NC test by Audio Science Review (Amir)
Logo Audio Science Review
Discover the DA-S250NC product sheet
Photo of Audiophonics DA-S250NC integrated amplifier
DA-S250NC
Integrated amplifier Class D NCore NC252MP DAC ES9038Q2M Bluetooth 5.0 2x250W 4 Ohm 32bit 768kHz DSD256
Key points of the DA-S250NC test by Audio Science Review
Overview of measurements from the DA-S250NC's DAC section on the pre-out RCA output
DAC measurement dashboard
The DAC panel shows an output level of 0.8Vrms. Distortion is less than -110 dB, but as the output level is rather low, noise drops the SINAD to 103 dB. Still, this is a good performance compared with many other devices on the market.
Signal-to-noise ratio is good enough for 16-bit content
DAC SNR measurement
Almost perfect linearity
DAC linearity measurement
Multitone is quite good until the upper registers
DAC multi-tone measurement
Overall, the DA-S250NC remains a good DAC, the real question is how does this performance impact the amplifier part?
Overview of DA-S250NC amplifier measurements on the speaker terminal output
Amplifier measurement dashboard
Measurements were taken via the USB input, with a volume setting of -16.5dB to obtain 5W of power. The DA-S250NC shows very good performance, placing it above the average of many of the products tested.
Noise performance is very good, reaching almost 16-bit SNR at 5 watts
SNR measurement of the amplifier section
Frequency response is very good, showing no dependence on impedance loading
Measuring the frequency response of the amplifier section
Crosstalk is better than the average of all the amps tested
Measurement of amplifier crosstalk
Extremely low distortion and noise levels for max. power of 205W
THD+N measurement of the amplifier section
A distortion level so low that the maximum power level is measured with a THD of 0.3%.
Maximum amplifier power measurement
Conclusion of the Audiophonics DA-S250NC test by Audio Science Review (Amir)
"The combination of a DAC and a Class D amplifier makes sense for most people who only want digital inputs. There are others than the DA-S250NC on the market, but most are generally not as good. Combining a DAC with a HYPEX amplifier, with an aesthetically pleasing front panel and remote control, seems to be the best option. Even if the DAC's performance is only just good, it matches up extremely well with the amplifier, which in turn offers very good measurements. All in all, the DA-S250NC is an appreciable device that I'd recommend!"
Audio Science Review Logo
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
