December 2023 : The selection of the month by Audiophonics
Posté le 2024-01-17 News, Monthly selection 1311
xxx
Discover the selection of the month by Audiophonics
December 2023
Discover Audiophonics' HiFi selection of the month, featuring the catalog's new highlights:  Matrix MINI-I PRO 4, SMSL SU-X, Topping D90 III, Fosi Audio ZA3, Audiophonics AP300-S500NC, Aune AR5000.
Matrix MINI-I PRO 4
Matrix MINI-I PRO 4
Versatile and compact, the Matrix Mini Pro 4 is a streamer that also fulfills the functions of a DAC and balanced headphone amplifier. It features an ESS9039Q2M DAC chip, a 3.46" HD touchscreen and extensive connectivity including an RJ45 port, HDMI ARC input, USB-C input, stereo RCA analog input and 4.4mm jack headphone output.
1049,00€ TTC (874,17€ HT)
SMSL SU-X
SMSL SU-X
The SMSL SU-X is a state-of-the-art DAC featuring two ES9039MSPRO chips, an XMOS XU316 USB interface and Bluetooth 5.1 functionality. It supports high-resolution streams up to PCM 32 bit 768kHz, DSD512 and includes an MQA/MQA-CD decoder. All in a sober, elegant case.
999,00€ TTC (832,50€ HT)
Topping D90 III
Topping D90 III
The Topping D90 III is a balanced DAC featuring two ES9039SPRO DAC chips, an XMOS XU-316 USB interface and an Altera MAX CPLD. It also features Bluetooth 5.1, a 12V trigger and a preamplifier function. This versatile DAC offers excellent performance and supports high-resolution streams up to PCM 32 bit 768kHz, DSD512 and MQA.
899,00€ TTC (749,17€ HT)
Triangle BOREA BR02 BR03 Connect
Fosi Audio ZA-3
The Fosi Audio ZA3 is a Class D stereo/mono amplifier based on the use of two TI TPA3255 amplifier chips mounted in DIP8. It can deliver 2x 150W or 1x 240W power at 4 ohms. It features an XLR balanced stereo input in addition to its RCA stereo input, as well as speaker terminals, an active subwoofer output and a 12V trigger.
149,00€ TTC (124,17€ HT)
Fosi Audio ZA-3
The Audiophonics AP300-S500NC is a stereo power amplifier based on a Hypex Ncore NC502MP amplifier module with its own power supply stage. It can deliver up to 2x 500W at 4 ohms, and features essential connectivity including a 12V trigger.
699,00€ TTC (582,50€ HT)
Aune AR5000
The Aune AR5000 is an open-back headphone featuring a Ø50mm MLD dynamic driver. With a sensitivity of 108dB and an impedance of 28 ohm, these headphones are easy to drive and offer high-end performance over a wide sound spectrum. It comes with a 2x 3.5mm jack to 3.5mm jack termination cable.
299,00€ TTC (249,17€ HT)
Aune AR5000
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
