O-NOORUS: The new Hi-Fi brand of powerful, compact Class D amplifiers for less than €100
Posté le 2024-01-26 News, New products, Good deals 3773
O-Noorus article banner
O-NOORUS
A range of integrated amplifiers
for less than €100
O-Noorus is a brand developing DACs, headphone amplifiers, integrated amplifiers and other quality audio devices at affordable prices. We'll concentrate here on its range of integrated amplifiers. It uses quality components and amplifier chips known on the market for their ability to deliver consistent power and audio quality, all incorporated in compact housings.
The entry-level of O-Noorus versatile integrated amplifiers: PA-70 and PA-316 (€70)
The PA-70 and PA-316 are both small Class D amplifiers. The PA-70 offers up to 2x 55W of power into 4 ohms (1% THD), while the PA-316 just exceeds it with up to 2x 60W of power into 4 ohms (1% THD). Both feature Bluetooth 5.0 functionality, a USB-A port (U-Disk + Audio-USB) and a subwoofer output for powering an active subwoofer. Features that are more than appreciable for small amplifiers offered at a very low price. The front panels of the PA-70 and PA-316 also feature 3 potentiometers: a volume control associated with an NJW1194 controller, and a gain control for bass and treble, each at +/- 10dB. Their interface also includes an RCA input and a stereo output on speaker terminals. The difference between these two brand references lies solely in the amplification chip used, with one Infineon MA12070 chip for the PA-70 and two TI TPA3116D2 chips for the PA-316. The strength of these small amplifiers simply lies in their versatility.
PA-70 VS PA-316
O-Noorus PA-70 picture
O-NOORUS PA-70
Amplifier Class D MA12070 Bluetooth 5.0 2x55W 4 Ohm
Discover the O-Noorus PA-70
O-Noorus PA-316 picture
O-NOORUS PA-316
Amplifier Class D 2x TPA3116D2 Bluetooth 5.0 2x60W 4 Ohm
Discover the O-Noorus PA-316
O-Noorus integrated amplifiers with balanced input: OA70 and OA316 (€85)
The OA70 and OA316 amplifiers are offered at a slightly higher price. This time, both feature one chip per channel. Two Infineon MA12070s for the OA-70 and two TI TPA3116s for the OA316. Like their predecessors, they feature Bluetooth 5.0 functionality thanks to a Qualcomm 32bit QCC3034 receiver chip supporting aptX and aptX HD codecs. Connectivity is less varied on these models, but we now find a balanced input on a 6.35mm TRS jack in addition to a stereo RCA input and an output on speaker terminals. The balanced stereo input on 6.35mm TRS connectors resolves potential ground loop problems and provides a purer signal. The front panel features a volume control and a source selection knob.
OA70 VS OA316
O-Noorus OA-70 picture
O-NOORUS OA70
Amplifiier Class D 2x MA12070 Bluetooth 5.0 2x65W 4 Ohm
Discover the O-Noorus OA70
Photo di O-Noorus OA316
O-NOORUS OA316
Amplifier Class D 2x TPA3116 Bluetooth 5.0 aptX HD 2x60W 4 Ohm
Discover the O-Noorus OA316
Versatile, powerful O-Noorus amplifiers : PA-98E and A80 (99€)
These two O-Noorus references have real differences that make the choice more difficult if you're hesitating between the two models.
Let's start with the PA-98E, a small amplifier capable of delivering up to 2x 125W into 4 ohms, thanks to a TDA7498E amplifier chip. It features the same front-panel design as the PA-70 and PA-316, with NJW1194 volume control and potentiometer for bass and treble adjustment. Extensive connectivity is also provided, with subwoofer output, USB-A input port and Bluetooth 5.0 receiver. In short, its strength lies in its power capacity, more than adequate for an amplifier with such a small form factor. With its 2x 125W at 4 ohms, it is capable of driving a large number of speakers available on the market, and of providing sound for a relatively large space.
The A80 is capable of delivering 2x 80W power at 4 ohms, thanks to two Infineon MA12070 chips. On the other hand, it features a more modern interface with a display and infrared remote control. Volume control is still possible via a potentiometer, while bass and treble are adjusted via the remote control. The rear panel features a subwoofer output, a Bluetooth 5.0 reception antenna and the classic stereo RCA input and output on speaker terminals. The USB port, on the other hand, is now a USB-C port coupled with a Realtek ALC44050 audio driver supporting up to 32bit 384kHz PCM. An AUX input on a 3.5mm jack is also available for an additional external source.
In their segment, the PA-98E and A80 are very good compact amplifiers offered at a more than reasonable price.
PA-98E VS A80
Photo du O-NOORUS PA98E
O-NOORUS PA-98E
Amplifiier Class D TDA7498E Bluetooth 5.0 2x125W 4 Ohm
Discover the O-Noorus PA-98E
Photo du O-NOORUS A80
O-NOORUS A80
Amplifier Class D MA12070 Bluetooth 5.0 Subwoofer 2x80W 4 Ohm
Discover the O-Noorus A80
The O-Noorus all-in-one digital amplifier: D3 (135)
Okay, so this one's a little over the announced budget of less than 100€, but how could we not introduce you to the D3? For an additional 35€, this magnificent little amplifier delivers 2x130W of power at 4 ohms, and features good quality components. This little gem features a TI TPA3255 Class D amplifier chip and an ES9023P DAC chip, all with coaxial, Toslink optical and USB-C digital inputs with Realteak 4050 driver (32bit 384kHz). The D3 offers a high level of compatibility via its USB-C port (Android TV, games console, etc.). There's also Bluetooth 5.0 and a 3.5mm AUX input. On the output side, there's a 2.1-channel interface with speaker terminals and subwoofer output. A color LED display provides clear information, and a remote control is included for quick and easy adjustment. This little amplifier is perfect for anyone needing power and digital or optical inputs.
D3
Photo du O-NOORUS D3
O-NOORUS D3
Amplifiier Class D TPA3255 Bluetooth 5.0 2x130W 4 Ohm Red
Discover the O-Noorus D3
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
