January 2024 : The selection of the month by Audiophonics
Posté le 2024-02-06 News, Monthly selection 1428
xxx
Discover the selection of the month by Audiophonics
January 2024
Discover Audiophonics' HiFi selection of the month, featuring the catalog's new highlights:  SMSL SH-X, Gustard H26, Tonewinner AD-89D, FiiO Q15, Dayton Audio TT-1BTW et Ibasso 3T-154.
SMSL SH-X
SMSL SH-X
The SMSL SH-X is a powerful, compact balanced headphone amplifier incorporating no less than 80 low-noise OPAs. It presents excellent measurements, features a large IPS display and 3 gain levels. It has three headphone outputs on the front and two line outputs on the rear, enabling it to be used as a preamplifier.
699,00€ TTC (582,50€ HT)
Gustard H26
Gustard H26
The Gustard H26 is a Class A balanced headphone amplifier/preamplifier that uses discrete components. It features 8 pairs of power transistors, two LME49720 double OPAs, two toroidal transformers and a relay volume control matrix. Its wide range of analogue connections means it can be adapted to suit any situation.
1149,00€ TTC (957,50€ HT)
Tonewinner AD-89D
Tonewinner AD-89D
The Tonewinner AD-89D is an all-in-one 2.1-channel Class A/B integrated amplifier capable of delivering 2x 130W power at 8 ohms. It has a wide range of on-board features: CD player, Bluetooth 5.0, local player, HDMI ARC input. Moreover, it has a wide range of connections with digital inputs and an option for use as a power amplifier within a complete sound system.
999,00€ TTC (832,50€ HT)
Benchmark
FiiO Q15
The Q15 from FiiO is portable headphone amplifier / DAC featuring two AKM AK4499EX + AK4191EQ chips, an XMOS XU316 USB interface and a Qualcomm QCC5125 Bluetooth chip. It supports high-resolution streams up to PCM 32bit 768kHz, DSD512 and MQA. It has a USB-C input, a coaxial SPDIF input and two headphone outputs: 3.5mm jack and 4.4mm balanced jack.
449,00€ TTC (374,17€ HT)
FiiO Q15
The Dayton Audio TT-1BTW vinyl turntable is a blend of vintage and modernism. It has a belt drive, an interchangeable Audio-Technica AT-VM95E pick-up and features such as Bluetooth transmission and a USB port. All in all, a quality turntable for 33T and 45T fans.
299,00€ TTC (249,17€ HT)
Ibasso 3T-154
The Ibasso 3T-154 in-ear monitors feature a dynamic driver and a 15.4 mm beryllium diaphragm. They use 3T magnetic flux technology with N55 neodymium magnets. This gives them superb transient response and accurate, detailed bass. A detachable cable with 0.78mm CIEM connector and interchangeable 3.5mm and 4.4mm jack termination is supplied.
149,00€ TTC (124,17€ HT)
Ibasso 3T-154
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
