Fosi Audio V3 review by AudioScienceReview
Posté le 2024-03-08 Tests & reviews, HiFi Tests 21060
Fosi Audio V3 amplifier picture
Discover Audio Science Review's test of the FOSI Audio V3 integrated amplifier. The V3 from Fosi Audio is a small, powerful and affordable amplifier featuring a host of high-quality components. In fact, a TI TPA3255 amplification chip enables it to develop up to 2x 225W of power at 4 ohms, so it can drive energy- and power-hungry speakers to sonorize a large space. Moreover, this little audiophile jewel is equipped with Elna and Wima capacitors, as well as a logarithmic volume control for much finer volume management. To top it all off, two NE5532 OPAs complete the amplification circuit for a beautiful coloration of the output signal. These OPAs are DIP8-mounted for easy replacement in case you wish to implement your favorite OPAs such as MUSES02, AOP2604AP or AOP2134PA, for example. On the rear panel of the V3, you'll find the essentials, with an RCA input, a main output on speaker terminals and a 3.5mm jack pre-out. All in all, the Fosi audio V3 concentrates on the essentials and manages to deliver top-level performance.
Complete test of the Fosi Audio V3 by Audio Science Review (Amir)
Audio Science Review Logo
FOSI AUDIO V3
Stereo Class D amplifier TPA3255 2x225W 4 Ohm
Discover the FOSI Audio V3
Key points of the FOSI AUDIO V3 test by Audio Science Review
Fosi Audio V3 measurement dashboard
Distortion is well maintained at -100 dB, limiting noise and allowing the SINAD to be around 88 dB. This puts the Fosi V3 ahead of most of the amplifiers tested in comparison.
FOSI AUDIO V3 measurement dashboard FOSI Audio V3 rating
Excellent SNR
The Fosi Audio V3's noise performance is very good for its class, with an SNR of 91dB at 5W power and up to 102dB at maximum power.
FOSI Audio V3 SNR measurement
Essentially flat frequency response at 4 ohm load
In terms of frequency response, a fairly flat curve can be observed with a 4 ohm load. However, with an 8 ohm load, a load dependency is observed, which tends to make the sound brighter or a little dull around 20 kHz. This load dependency can be corrected with an equalizer.
FOSI AUDIO V3 frequency response
Multitone and 19+20 kHz show good performance for Fosi Audio V3's class
FOSI AUDIO V3 multitone measurements
Significant output power
FOSI AUDIO V3 output power
FOSI AUDIO V3 inside pictures
FOSI Audio V3 inside pictures
Conclusion of the Fosi Audio V3 test by Audio Science Review
"The Fosi Audio V3 is a Class D amplifier featuring quality components integrated into an aesthetically pleasing case for a very attractive price. In terms of noise and distortion measurements, it beats many amplifiers on the market, and is therefore one of our recommendations!"
Audio Science Review logo
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
