March 2024 : The selection of the month by Audiophonics
Posté le 2024-04-04 News, Monthly selection 1100
xxx
Discover the selection of the month by Audiophonics
March 2024
Discover Audiophonics' HiFi selection of the month, featuring the catalog's new highlights:  Amanero COMBO768, Moondrop Golden Ages, Kiwi Ears x Crinacle Singolo, IKKO ActiveBuds, FiiO K19 and Hidizs SD2.
AMANERO COMBO768
AMANERO COMBO768
The Amanero Combo768 is a USB audio interface designed for OEM applications. This interface supports USB PCM streams up to 1536kHz, and converts them to I2S or native DSD streams on a solder pad output. DSD DoP512 and DSD1024 streams are also accepted by the USB input. Conversion is based on a Cortex-M7 NXP IMXRT1011  processor and a W25Q32 external flash.
79,00€ TTC (65,83€ HT)
MOONDROP GOLDEN AGES
The Moondrop Golden Ages Bluetooth 5.3 IEM wireless earphones feature a 13mm wideband super-linear planar magnetic driver. At the cutting edge of wireless transmission, these headphones support LDAC and LC3 codecs thanks to the Bluetooth LE Audio standard. They feature a noise reduction mode and a transparency mode for a better user experience.
85,00€ TTC (70,83€ HT)
KIWI EARS X CRINACLE SINGOLO
Kiwi Ears and Crinacle collaborate to develop the Singolo dynamic IEM earphones. These IEMs feature a 11mm driver and the Kiwi Acoustic Resonance System. Their sensitivity and 32Ω impedance make them easy to drive. A detachable 2x CIEM 0.78mm to 3.5mm jack termination cable is supplied with the package.
89,00€ TTC (74,17€ HT)
Discover Topping Professional products
IKKO ActiveBuds
iKKO ActiveBuds wireless earphones are Bluetooth 5.3, 4G and Wifi IEMs. In fact, you can turn their box into a true control center with access to streaming services. ActiveBuds also feature ChatGPT, instant translation and an equalizer. As well as being versatile and ultra-connected, the sound quality is also impressive, thanks in particular to a 10mm Silicium Crystal Ceramic diaphragm.
329,00€ TTC (274,17€ HT)
 IKKO ActiveBuds
FiiO K19
With the K19, FiiO unveils a DAC headphone amplifier featuring two ES9039MSPRO DAC chips and two THX AAA-788+ modules. This means it can handle streams up to PCM 32bit 768kHz and DSD512, while delivering power up to 2x 8000mW at 32 ohms. Its comprehensive digital connectivity, with HDMI, HDMI e-ARC ports and Bluetooth 5.1, makes it a device of choice. The package is completed by an ADI SHARC + ADSP-21565 DSP for 31-band parametric EQ.
1390,00€ TTC (1158,33€ HT)
FiiO K19
Hidizs SD2
The Hidizs SD2 is a compact, high-performance USB-C to 3.5mm jack dongle DAC and headphone amplifier. Equipped with an ES9270 DAC chip, it supports 32bit 384kHz PCM and DSD128 streams. It delivers maximum power of 2x 70mW at 32Ω and features a built-in equalizer. It's the perfect ally for enjoying quality sound reproduction, even on the move.
39,00€ TTC (33,25€ HT)
Hidizs SD2
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
