April 2024 : The selection of the month by Audiophonics
Posté le 2024-04-24 News, Monthly selection 1301
xxx
Discover the selection of the month by Audiophonics
April 2024
Discover Audiophonics' HiFi selection of the month, featuring the catalog's new highlights: Audiophonics AP310-P250NC, Letshuoer Cadenza 4, Moondrop Cosmo, SMSL DO200 Pro, Ifi Audio ZEN V3 et Audiophonics HPA-DM500NIL.
Versatile and high-performance, the AP310-P250NC is an analog integrated amplifier based on a Hypex NCore NC252MP class D amplifier module delivering up to 2x250W into 4Ω. A ByPass input enables this amplifier to operate within a 5.1 home theater system if coupled with an AV receiver, for example.
699,00€ TTC (582,50€ HT)
Letshuoer Cadenza 4
Letshuoer Cadenza 4
Letshuoer Cadenza 4 dynamic hybrid in-ear monitors feature a 10mm diameter beryllium-plated dynamic driver and three balanced armature drivers. Their 15 ohm impedance and 102dB sensitivity make them easy to drive. A detachable cable with interchangeable termination completes the package.
249,00€ TTC (207,50€ HT)
Moondrop Cosmo
Moondrop Cosmo
The high-end Moondrop Cosmo is a circumaural open magnetic planar headphone. It features a Ø10cm nanoscopic diaphragm and a balanced array of magnets. Its extended frequency response of 13Hz-58kHz delivers rich, detailed sound reproduction.
999,00€ TTC (832,50€ HT)
Discover the Subwoofer Velodyne
SMSL DO200 Pro
SMSL innovates with its high-performance DO200 Pro balanced DAC, featuring no less than 12 CS43131 DAC chips and an XMOS XU316 USB interface. It supports high-resolution streams up to PCM 32bit 768kHz, native DSD up to DSD256, as well as MQA/MQA-CD streams. It features extensive connectivity, including Bluetooth 5.1 and an HDMI ARC port, as well as a preamplifier function for a wide range of configurations.
429,00€ TTC (357,50€ HT)
 SMSL DO200 PRO
Ifi Audio ZEN V3
This Ifi Audio DAC/headphone amplifier features a Burr Brown conversion chip and a USB XMOS interface, enabling it to support high-resolution streams up to PCM 768kHz, DSD512 and MQA. In addition to its analog RCA output and balanced 4.4mm jack line, it features two headphone outputs, balanced and unbalanced.
229,00€ TTC (190,83€ HT)
Ifi Audio Zen V3
The Audiophonics HPA-DM500NIL is a dual-mono power amplifier based on two Hypex Nilai500DIY modules, delivering 2x 500W @ 4 ohm power with very low noise and distortion for precise, clear sound reproduction. It features analog RCA and XLR inputs and a speaker output, as well as two IN and OUT triggers.
2190,00€ TTC (1825,00€ HT)
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
