May 2024 : The selection of the month by Audiophonics
Posté le 2024-05-31 News, Monthly selection 1159
xxx
Discover the selection of the month by Audiophonics
May 2024
Discover Audiophonics' HiFi selection of the month, featuring the catalog's new highlights: Audiophonics LPA-M750ET, LAiV Harmony, HiFiMAN Ananda Nano, SMSL A200, Hidizs S8 Pro Robin, Hibiki SDS.
The LPA-M750ET is a Class D power amplifier featuring mono architecture and a Purifi 1ET9040BA module for power up to 1x750W at 4 ohms. A 1200W Hypex SMPS1200A180 power supply powers the amplifier, all implemented in a sturdy aluminum chassis.
1490,00€ TTC (1241,67€ HT)
LAiV HARMONY
LAiV HARMONY
LAiV's R2R discrete balanced DAC supports up to PCM 768kHz and DSD512. It features high-quality components such as a Crystek CCHD-957 internal oscillator clock and an Intel Altera Cyclone FPGA processor. Aesthetically and ergonomically, this DAC also shows excellent performance.
2999,00€ TTC (2499,17€ HT)
HiFiMAN Ananda Nano
HiFiMAN Ananda Nano
HiFiMAN's Ananda Nano headphones are open circumaural planar magnetic headphones. Lightweight and comfortable, they feature nanometric membranes. Its 94dB sensitivity and 14 ohm impedance make it easy to drive with any DAP.
555,00€ TTC (462,50€ HT)
SMSL A200
The SMSL A200 is a Class D amplifier featuring two Infineon MA12070 chips for power up to 2x70W at 4 ohms. An RCA input and numerous digital inputs (USB, Bluetooth, HDMI ARC, etc.) ensure a high level of integration. Finally, two rounded VU meters and a display enhance the user experience.
259,00€ TTC (215,83€ HT)
SMSL A200
Hidizs S8 Pro Robin
The S8 Pro Robin from Hidizs is a balanced portable DAC/headphone amplifier combo. It features two CS43131 DAC chips and supports up to PCM 32Bit 384kHz and DSD256. Output power reaches up to 2x160mW at 32 ohms on its balanced 4.4mm jack output. Input is via USB-C connector.
85,00€ TTC (70,83€ HT)
Hidizs S8 Pro Robin
Hibiki SDS
The Hibiki SDS is a dual-mono R2R DAC with the almost unique function of being able to increase the sampling rate of any DSD1024 source in order to offer the highest possible resolution signal for conversion by the resistor network. It features numerous digital inputs and two analog XLR and RCA outputs.
3990,00€ TTC (3325,00€ HT)
Hibiki SDS
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
