June 2024 : The selection of the month by Audiophonics
Posté le 2024-07-08 News, Monthly selection 1090
xxx
Discover the selection of the month by Audiophonics
June 2024
Discover Audiophonics' HiFi selection of the month, featuring the catalog's new highlights: Audiophonics AP310-PREAMP, FiiO SR11, Shanling Onix Overture XM5, SMSL H400, Thieaudio Oracle MKIII, SMSL DL100.
The AP310-PREAMP is a balanced, purely analog preamplifier based on a MUSES72320 volume controller and featuring full connectivity. The MUSES72320 volume controller offers excellent performance with very low noise and distortion, thanks in particular to its resistor ladder circuit. The whole unit is housed in a sober, elegant aluminum case.
349,00€ TTC (290,83€ HT)
FiiO SR11
FiiO SR11
The compact, high-performance SR11 streamer from FiiO is based on an X2000 processor and is compatible with numerous network protocols such as AirPlay and Roon Ready, thanks to its 2.4/5GHz WiFi receiver. Simple to use, this little device acts as a veritable gateway between your streaming services and your audio system. It supports high-resolution PCM 32bit 768kHz and DSD DoP256 streams via its USB outputs.
129,00€ TTC (107,50€ HT)
Shanling's Onix Overture XM5 is a high-end DAP featuring an ES9039PRO DAC chip and XMOS XU316 USB interface. It supports sampling rates up to PCM 32 bit 768kHz and DSD512. On the amplification side, two TPA6120 chips give it power of up to 1070mW at 32Ω, as well as gain control for great compatibility.
825,00€ TTC (687,50€ HT)
Discover the SMSL VMV T2 MQA player
SMSL H400
The SMSL H400 is a headphone amplifier/preamplifier featuring balanced architecture, an attractive IPS display, as well as a grounded terminal block and a grounded/floated selector switch. Powerful, it delivers up to 15W of power at 16 ohms and up to 7.5W at 32 ohms. A 3-level gain control enables it to adapt to the majority of headphones and earphones on the market.
499,00€ TTC (415,83€ HT)
SMSL H400
Thieaudio Oracle MKIII in-ear monitors are hybrid headphones. They feature no fewer than 6 drivers, including two with IMPACT² technology. Equalization delivers balanced sound, with smooth highs and deep bass. An audiophile cable with interchangeable termination is supplied.
599,00€ TTC (499,17€ HT)
SMSL DL100
The SMSL DL100 DAC/headphone amplifier incorporates a combo of 4 CS43131 chips, an XMOS XU316 USB interface and a Qualcomm Bluetooth receiver chip. It can decode high sampling rates, up to PCM 32bit 768kHz, DSD DoP64, DSD256 and MQA/MQA-CD. Two headphone outputs powered by an amplifier circuit comprising 3 OPA1612A amplifiers complete the package.
215,00€ TTC (179,17€ HT)
SMSL DL100
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
