July 2024 : The selection of the month by Audiophonics
Posté le 2024-08-02 News, Monthly selection 2634
xxx
Discover the selection of the month by Audiophonics
July 2024
Discover Audiophonics' HiFi selection of the month, featuring the catalog's new highlights: Topping B200, iFi Audio ZEN CAN 3, Fosi Audio HT4S, SMSL PS200, iBasso DC07PRO, Auralic Aries S1.
Topping B200
Topping B200
The Topping B200 power amplifier is a mono amplifier based on a discrete component NFCA amplifier circuit capable of delivering up to 200W of power (THD=1%) under both 4 ohm and 8 ohm loads. It boasts a dynamic range of 145dB and an extremely low level of distortion.
599,00€ TTC (499,17€ HT)
iFi Audio ZEN CAN 3
iFi Audio ZEN CAN 3
The iFi Audio ZEN CAN 3 is a Class A headphone amplifier with a purely analog design, devoid of any DSP for natural sound reproduction. It features 5 equalization modes: gaming, movies, XMEMS, Xbass + and Xspace. It has been specially designed to power a wide range of headphones and IEMs on the market, thanks to its gain control and power handling of up to 2000mW on its balanced output.
229,00€ TTC (190,83€ HT)
Fosi AUdio HT4S
Fosi Audio HT4S
Fosi Audio's HT4S is a compact multi-channel integrated amplifier based on two TPA3116 amplifier chips. Its connectivity allows 5.0, 5.1 or 4.1 use, depending on whether or not it's coupled with a passive or active subwoofer. It is capable of delivering 4x30W + 60W at 4 ohms in 4.1 configuration and 5x30W at 4 ohms in 5.0/5.1 configuration. This versatile multichannel amplifier is also suitable for home cinema or gaming use with exciters / bass-shakers, for example.
115,00€ TTC (95,83€ HT)
Contest Fosi Audio
Win a pair of the new V3 Mono amplifier, with Fosi Audio and Audiophonics! Several prizes are up for grabs!
The Fosi Audio V3 Mono is no less than 240W of power (4 Ohm) per block, for a truly high-performance dual-mono integration.
Enter the competition on Facebook or Instagram before the draw takes place on August 16!
SMSL PS200
The SMSL PS200 is a compact DAC featuring an ES9039Q2M chip, XMOS XU316 USB interface and four OPAs. It supports sampling rates up to PCM 32bit 768kHz, native DSD up to DSD512, as well as MQA and MQA-CD streams. It also features Bluetooth reception, and a switch that lets you select the USB UAC1 or UAC2 protocol for driverless compatibility with video game consoles.
99,00€ TTC (82,50€ HT)
SMSL PS200
iBasso DC07PRO
The iBasso DC07Pro is a portable DAC/headphone amplifier. Compact, it is equipped with four CS43131 chips and a custom-designed FPGA, enabling it to support sampling rates up to PCM 32bit 768kHz and DSD512. Its low power consumption and high output level of 2x430mW at 32Ω make it the perfect travel companion.
199,00€ TTC (165,83€ HT)
iBasso DC07PRO
Auralic Aries S1
Benefiting from Auralic's technologies and know-how, the Aries S1 network player acts as a true gateway for connecting your sound system to the network and accessing numerous streaming or storage services. Playlists, caching, stable playback, bit-perfect and multi-room are just some of the features Auralic offers with this technological gem. It supports up to PCM 32bit 384kHz and DSD512.
1999,00€ TTC (1665,83€ HT)
Auralic Aries S1
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
