Discover the new PURIFI 1ET6525SA amplifier module!
Posté le 2024-08-19 News, New products 6276
Couverture blog article PURIFI 1ET6525SA
Mono PURIFI amplifier module 1ET6525SA
High-precision power and performance coming soon to a new range of Audiophonics amplifiers!
PURIFI 1ET6525SA module picture
With its new 1ET6525SA class D mono amplifier module, PURIFI offers a model with exceptionally precise performance, also capable of developing 480W of power at 4Ω. Based on PURIFI's proprietary EIGENTAKT amplification technology, it boasts ultra-low-noise performance, THD and IMD close to perfection, enabling it to handle the most complex signals for the finest final audio rendering. This new amplifier module is the fruit of PURIFI's research into non-linear control theory. In particular, this technological advance has enabled to greatly improve the feedback circuit on the 1ET6525SA module, boosting its overall technical performance. As usual, PURIFI offers a solution for the most demanding audiophiles. Continuing our collaboration with PURIFI, Audiophonics will be developing a new range of amplifiers incorporating the 1ET6525SA module, to offer you the best possible amplification solution.
PURIFI 1ET6525SA highlights :
  • Mono Class D amplifier module with analog input
  • Very low THD and IMD
  • Ultra-low noise and high efficiency
  • Frequency response invariant to any impedance load
  • 480W into 4Ω and 230W into 8Ω output power (THD=1%)
PURIFI 1ET6525SA module characteristics
Output power230W @ 8 ohm (THD=1%)
480W @ 4 ohm (THD=1%)
510W @ 2 ohm (THD=1%)
Output current≈25A
THD+N< 0.0001% (-120dB) @100W, 4Ω, 20-20kHz
Dynamic range137dB(A)
Output noise≈6.6uV(A)
Gain12.3dB
Output impedance< 30uΩ @ 1kHz
Efficiency> 94%
Idle losses (output stage)≈1.6W
Power supply±32V to ±65V DC
Dimensions82x63x33mm
PURIFI 1ET6525SA module measurements
1ET6525SA amplifiers teasing
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
