August 2024 : The selection of the month by Audiophonics
Posté le 2024-09-02 News, Monthly selection 891
xxx
Discover the selection of the month by Audiophonics
August 2024
Discover Audiophonics' HiFi selection of the month, featuring the catalog's new highlights: Topping B100, Moondrop Ultrasonic, Shanling M1 PLUS, WiiM Ultra, Aiyima B07, SMSL D10 et IEAST AUDIOCAST AMP50/PRO M20.
Topping B100
Topping B100
The Topping B100 mono power amplifier, little brother of the B200, is a state-of-the-art amplifier in terms of performance. It is based on Topping's proprietary amplifier module, enabling it to develop 100W of power at 4 ohms, while maintaining a THD+N of less than 1% and a DNR of 151dB. Ultra high-performance, the B100 is the amplifier of choice for a dual-mono system.
299,00€ TTC (249,17€ HT)
Moondrop Ultrasonic
Moondrop Ultrasonic
Moondrop's Ultrasonic wireless earphones feature a balanced armature tweeter with lithium-magnesium alloy diaphragm and a 13mm dynamic driver with sapphire composite diaphragm, ensuring high-quality sound reproduction across the entire spectrum. In addition, these in-ear monitors are compatible with Bluetooth LDAC and LC3 codecs for fast Bluetooth transmission, without losing any of the detail of your favorite music.
75,00€ TTC (62,50€ HT)
Shanling M1 PLUS
Shanling M1 PLUS
With the M1 Plus, Shanling offers a technical and aesthetic evolution of the M1S high-fidelity DAP. This Plus version boasts an improved digital/analog conversion stage, now based on an ESS ES9069Q chip, a new amplifier stage and a Bluetooth receiver updated to version 5.2. It supports sampling rates up to 32bit 768kHz and DSD512.
199,00€ TTC (166,58€ HT)
IEAST Audiocast
WiiM Ultra
The Wiim Ultra is the new reference in the world of network players. An ES9038Q2M DAC chip enables it to support 32bit 384kHz PCM sampling rates. It features a 3.5” color touchscreen and a physical navigation button, and its extensive connectivity including WiFi 6E and Bluetooth 5.3 means you can access your music quickly and easily.
399,00€ TTC (332,50€ HT)
WiiM Ultra
Aiyima B07
Aiyima's B07 is an integrated amplifier with 3 channels, one of which is dedicated to the subwoofer, plus an auxiliary output. Its six NE5532 OPAs and TPA3255 amplifier chip deliver 2x 250W + 300W output power at 4 ohms. To ensure flexibility of use, it also features a Bluetooth 5.2 chip compatible with aptX, aptX Low Latency and aptX HD.
149,00€ TTC (124,17€ HT)
Aiyima B07
SMSL D10
The SMSL D10 is a high-performance portable headphone amplifier/DAC. It is based on two Cirrus Logic CS43131 chips, enabling it to support sampling rates up to PCM 32bit 384kHz and DSD256. These chips also provide substantial headphone amplification, with output power up to 500mW at 32 ohms. Its interface is straightforward, with a USB-C input and two headphone outputs: 3.5mm jack and balanced 4.4mm jack.
64,90€ TTC (54,08€ HT)
SMSL D10
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
