September 2024 : The selection of the month by Audiophonics
Posté le 2024-10-01 News, Monthly selection 1002
xxx
Discover the selection of the month by Audiophonics
September 2024
Discover Audiophonics' HiFi selection of the month, featuring the catalog's new highlights: Topping D90 III Discrete, Letshuoer S08 Fourth Generation, Aiyima A70 Mono, HiFiMAN EF499, Aune AR7000, Shanling EC SMART and Bluesound NODE streamers.
Topping's D90 III Discrete balanced DAC uses a 100% discrete digital-to-analog conversion module. Here, conversion is performed by a PSRM module per channel, enabling conversion up to 32bit 768kHz PCM and native DSD512. This DAC also incorporates a Qualcomm QCC5125 Bluetooth 5.1 chip, as well as a 12V trigger input and output on the rear panel.
999,00€ TTC (832,5€ HT)
Letshuoer S08
Letshuoer S08
Letshuoer S08 in-ear monitors are planar magnetic IEMs. They feature a quality design with a custom Ø13mm planar magnetic diaphragm and dual coils. The SR08's 26ohm impedance and 105dB sensitivity make them easy to drive. A detachable audiophile cable with silver-plated copper conductors and interchangeable 3.5mm jack / 4.4mm balanced termination completes the package.
89,90€ TTC (74,92€ HT)
Aiyima A70 Mono
Aiyima A70 Mono
The Aiyima A70 Mono is a Class D amplifier based on a circuit comprising a TPA3255 amplifier chip and a NE5532 OPA. It can deliver power up to 300W at 4 ohms. It features a PFFB circuit for low distortion and noise reduction. Its connectors enable it to power a passive subwoofer, a passive speaker or an active subwoofer.
119,00€ TTC (99,17€ HT)
HiFiMAN EF499
HiFiMAN's EF499 is a DAC/headphone amplifier. It offers a warm sound resulting from R2R digital/analog conversion, as well as an output level of 4.35W at 32Ω, enabling it to drive a wide range of headphones. Its comprehensive connectivity makes it a highly flexible device, capable of fitting into a wide range of configurations.
379,00€ TTC (315,83€ HT)
HiFiMAN EF499
Aune SR7000
Aune's SR7000 is a closed-back circumaural headphone with Ø50mm MLD (“Multi-Layer Distributed”) dynamic drivers. Its design, combining a composite ceramic membrane and flexible suspension, enables it to offer a frequency response ranging from 5Hz to 45000Hz. Its 55 ohm impedance and 106dB sensitivity make it relatively easy to control.
639,00€ TTC (532,50€ HT)
Aune SR7000
Shanling EC SMART
The Shanling EC Smart is an affordable, high-performance CD player with an atypical, resolutely modern design. With its vertical format, the EC Smart accommodates CDs just behind its control panel, which can be rotated. At the heart of this design gem is a renowned optical drive, the Sanyo DA11. The audio circuit uses a Cirrus Logic CS43131 DAC capable of delivering precise, faithful sound reproduction.
149,90€ TTC (124,17€ HT)
Shanling EC SMART
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
