October 2024 : The selection of the month by Audiophonics
Posté le 2024-11-05 News, Monthly selection 856
xxx
Discover the selection of the month by Audiophonics
Septembre 2024
Discover Audiophonics' HiFi selection of the month, featuring the catalog's new highlights: Ruark Audio R610, Thinkya DVR-102, FiiO KA15, Shanling HW-600, Moondrop Discdream 2 Ultra, SMSL RAW HA1 and Eversolo DMP-A10 streamers.
Ruark Audio R610
Ruark Audio R610
The R610 from Ruark Audio is a multifunctional amplifier designed to be the heart of your HiFi installation. In addition to its 2x75W output power, it also has steamer and phono amp functions, as well as Bluetooth and HDMI ARC/eARC connectivity, ensuring ultimate versatility housed in a classy case.
1390,00€ TTC (1158,33€ HT)
Thinkya DVR-102
Thinkya DVR-102
Thinkya unveils a singular device with its DVR-102, a Class AB integrated amplifier using ECC83/ECC82 tubes for its preamplification stage and Toshiba PNP A1941 and NPN C5198 transistors for its power stage. Its output on loudspeaker terminals is capable of delivering 2x60W at 4Ω, enough to soundtrack a beautiful space.
479,00€ TTC (399,17€ HT)
FiiO KA15
FiiO KA15
With the KA15, FiiO offers a portable headphone amplifier and DAC based on a pair of CS43198 chips for digital/analog conversion. It supports sampling rates up to PCM 32bit 768kHz and DSD256. Amplification, meanwhile, is handled by two SGM8262 OPAs for a maximum output power of 2x560mW at 32Ω. Its original, retro look is also pleasing.
109,00€ TTC (90,83€ HT)
Lecteur réseau DMP-A10
Shanling HW600
Shanling HW600 are high-end supra-aural headphones featuring a planar magnetic transducer measuring no less than 110x86mm. Its design uses high-quality materials, and its appearance is most elegant. Its 30 ohm impedance and 104dB sensitivity make these headphones easy to drive, and adaptable to a wide range of devices.
1099,00€ TTC (915,83€ HT)
Shanling HW600
Moondrop's Discdream 2 Ultra is a portable CD player with a neat servo architecture, based on a pair of Cirrus Logic CS43131 DAC chips to deliver the best possible sound reproduction. It has been designed to be as versatile as possible, and can be used both as a portable CD player and as a CD player in a fixed installation, or even as a DAC/headphone amplifier when connected to a computer.
319,00€ TTC (265,83€ HT)
SMSL RAW-HA1
With the SMSL RAW-HA1, the brand unveils a versatile, high-performance integrated amplifier/headphone amplifier. It's capable of developing an output power of up to 2x165W at 4 ohms. The headphone amplifier features a Cirrus Logic CCS43131 hybrid DAC/headphone amplifier chip with two outputs: unbalanced 6.35mm jack and balanced 4.4mm jack.
269,00€ TTC (224,17€ HT)
SMSL RAW-HA1
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
