November 2024 : The selection of the month by Audiophonics
Posté le 2024-12-10 News, Monthly selection 1041
xxx
Discover the selection of the month by Audiophonics
Septembre 2024
Discover Audiophonics' HiFi selection of the month, featuring the catalog's new highlights: Eversolo AMP-F10, FiiO BTR17, Moondrop X Singer Edge, SMSL PA40, NF ACOUS NM20, Shanling EH1 and the LAiV Harmony HP2A preamplifier/headphone amplifier.
Eversolo AMP-F10
Eversolo AMP-F10
Eversolo has designed the AMP-F10 class AB power amplifier to accompany its new streamer, the DMP-A10. This amplifier features a double mono balanced architecture with no less than five MOSFET transistors per channel. It can deliver up to 2x320W at 4 Ohm and 2x200W at 8 Ohm. It can also be bridged in mono mode.
2579,00€ TTC (2149,17€ HT)
FiiO BTR17
FiiO BTR17
With the BTR17, FiiO offers a portable headphone amplifier and DAC equipped with a pair of ESS ES9069Q chips for high-quality digital-to-analog conversion, supporting audio signals up to 32bit 768kHz PCM and native DSD512. Amplification is based on THX-AAA 78+ chips, using a balanced circuit consisting of eight OPAs divided into four channels, offering natural sound and power up to 2x650mW at 32Ω.
199,00€ TTC (165,63€ HT)
Moondrop x Singer Edge
With the Edge, Moondrop offers LDAC-compatible wireless Bluetooth headphones featuring a 40mm low-distortion driver with titanium-plated composite diaphragm for high-definition, naturally textured sound. These headphones benefit from Moondrop's expertise in noise reduction, incorporating hybrid ANC and beamforming reduction for clear calls.
79,90€ TTC (66,58€ HT)
Préamplificateur Amplificateur casque LAiV HP2A
SMSL PA40
SMSL's PA40 is an integrated amplifier using an Infineon MA5332MS class D amplifier chip, capable of delivering a power of 2x160W into 4Ω with a THD of just 0.004%, ensuring crystal-clear sound reproduction. In addition, a very low-distortion NJU7391 volume control chip enables precise management of volume attenuation without altering the final sound rendering.
159,00€ TTC (132,50€ HT)
SMSL PA40
NF ACOUS NM20
With the NM20, NF ACOUS presents in-ear monitors designed for professional use, thanks to their linear, extended frequency response from 9Hz to 40kHz. They use a MC2L-100P dynamic driver for sound reproduction as close as possible to the source file. Their 32-ohm impedance and 108dB sensitivity make them easy to control, and compatible with a wide range of Hi-Fi equipment.
109,00€ TTC (90,83€ HT)
NF ACOUS NM20
Shanling EH1
With the EH1, Shanling presents a compact, high-performance desktop DAC with a modern design. It's based on a Cirrus Logic CS43198 DAC chip, capable of handling high-resolution sampling rates up to PCM 32bit 768kHz and native DSD up to DSD512. Headphone amplification uses two SGM8262-2 OPAs and includes gain control, offering output power of up to 2x1015mW at 32 ohms.
199,00€ TTC (165,83€ HT)
Shanling EH1
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
