December 2024 : The selection of the month by Audiophonics
Posté le 2025-01-09 News, Monthly selection 1037
xxx
Discover the selection of the month by Audiophonics
December 2024
Discover Audiophonics' HiFi selection of the month, featuring the catalog's new highlights: SMSL PA200, xDuoo XD05T, Ibasso Gelato, SMSL RAW PRO-DAC1, FiiO DM13BT, Topping Centaurus et FiiO S15 streamer.
SMSL PA200
SMSL PA200
SMSL unveils its PA200, a singular amplifier somewhere between a power amplifier and an integrated amplifier. The latter is capable of operating both in stereo with volume control and in mono as a pure power amplifier, and relies on Infineon GaN FET transistors. It can deliver up to 2x160W at 4 Ohm via its stereo RCA input, and up to 1x400W at 4 Ohm via its mono XLR input.
449,00€ TTC (374,17€ HT)
xDuoo XD05T
xDuoo XD05T
The xDuoo XD05T portable DAC and headphone amplifier is a high-performance device where cutting-edge technology meets vintage. It's based on the use of tubes machined in the 60s, transistors as well as two ES9039Q2M DAC chips, an XMOS XU316 USB interface and an FPGA. It can drive headphones with impedances from 32Ω to 300Ω without difficulty, while supporting high-resolution sampling rates up to PCM 32Bit 768kHz, DSD512 and MQA x8 via its USB-C input.
549,00€ TTC (457,50€ HT)
Ibasso Gelato
Ibasso Gelato
iBasso's Gelato are affordable, high-quality dynamic in-ear monitors. Equipped with a Ø10mm dynamic diaphragm and a 0.03 mm CCAW coil, they offer a very high level of performance. Their 18-ohm impedance and 108 dB sensitivity make them easy to drive. Their extended frequency response (20Hz-40kHz) enables them to faithfully reproduce all musical sources.
22,90€ TTC (19,08€ HT)
Streamer FiiO F15
SMSL RAW PRO-DAC1
The SMSL RAW PRO-DAC1 is a precise, high-performance DAC based on an ESS ES9039MSPRO DAC chip and an XMOS XU-316 USB interface. It is therefore able to support high-resolution sampling rates up to PCM 32bit 768kHz, DSD512 and MQA/MQA-CD. In addition, it features Bluetooth functionality thanks to the latest Qualcomm QCC5125 chip supporting aptX HD and LDAC (24bit/96kHz) codecs for extremely reliable wireless transmission.
699,00€ TTC (582,50€ HT)
SMSL RAW PRO-DAC1
FiiO DM13 BT
FiiO's DM13 BT is a portable CD player with a sleek design and undeniable internal component quality. Its aluminum chassis houses two Cirrus Logic CS43198 DAC chips to offer digital-to-analog conversion of your favorite CDs as close to the original as possible. The 2x660mW amplification at 32Ω provided by the balanced outputs means you can easily plug in any headphones or amplifier.
149,00€ TTC (124,17€ HT)
FiiO DM13BT
TOPPING CENTAURUS
Topping has teamed up with Holo Audio to design its new Centaurus balanced R2R DAC. This new high-performance device is based on an ALTERA MAX II CPLD and no less than eight R2R resistor networks in a balanced configuration. It boasts full connectivity with balanced XLR and unbalanced RCA outputs (variable and fixed), as well as numerous digital inputs, and supports sampling rates up to PCM 32Bit 768kHz and DSD512.
999,00€ TTC (832,50€ HT)
TOPPING CENTAURUS
Laisser un commentaire Leave a Reply
Vous devez être connecté pour publier un commentaire.
Rechercher dans le blog
Blog categories
Latest Comments
Prev
Next
