TINYSINE AUDIO-B Bluetooth 5.0 Multipoint Audio Receiver Module
AudioB Bluetooth 5.0 Multipoint Audio Receiver Module(Apt-X)
Reference : 14023
22,90 €tax incl.
19,08 € tax excl.
Shipping date: 30-07-2024.
TinySine Bluetooth Receiver 5.0
Bluetooth 5.0 / Multipoint
Ideal for the construction of a Bluetooth amplifier, this bluetooth 5.0 multipoint stereo receiver works with a Qualcomm CSR8675 chip. Makers will appreciate its ease of integration with its SMA antenna connector forincreased reception range on the 2.4 bands and its audiooutput already mounted on two rows of 10 pins allowing high quality audio streams.
The chip supports Bluetooth for an audio playback close to CD quality, with an intelligent compression ratio according to the transferred file format to avoid compressive redundancy that may unnecessarily affect the signal during conversion.
Finally, this receiver is multipoint, that is to say, it can be paired simultaneously with multiple devices. This makes it an ideal candidate for an integrated and versatile mobile amplifier, or even an car sound system.
Dimensions & distances
Dimensions Mounting hole spacing audiophile Bluetooth receiver module
single-ended output
Bluetooth 5.0 unbalanced output
single-ended output for headphones or small speakers
Bluetooth 5.0 headphone output
differential signal output
differential amplifier bluetooth 5.0
Pinout
Module not replaceable by an Audio-B Plus, the pinout being different.
TypeBluetooth receiver
Standard5.0
MultipointYes
Qualcomm audio HVAC TechnologyYes
Qualcomm Technology TrueWirelessYes
Reception range10-15m
Antenna connectorSMA
Supports smartphone applications-
Dimensions33.6 x 21mm
OutputI2S
