Bluetooth 5.0 Board CSR8675 aptX HD DAC PCM5102A 24bit 48kHz
This small Bluetooth 5.0 reception module is based on a Qualcomm CSR8675 chip and a PCM5102A DAC for the digital/analog conversion of the audio signal. Very easy to use, it will allow you, integrated into an audio system, to enjoy a Bluetooth reception to broadcast your music remotely, from a smartphone for example.
Reference : 15368
42,90 €tax incl.
35,75 € tax excl.
Shipping date: 24-04-2025.
Bluetooth Board
Module Bluetooth 5.0 CSR8675 aptX HD DAC PCM5102A 24bit 48kHz
This small Bluetooth 5.0 reception module is based on a Qualcomm CSR8675 chip and a PCM5102A DAC for the digital/analog conversion of the audio signal. Very easy to use, it will allow you, integrated into an audio system, to enjoy a Bluetooth reception to broadcast your music remotely, from a smartphone for example. In addition, it supports the transmission codecs aptX, aptX LL and aptX HD, ensuring a stable and fast broadcast for a quality close to that of CD. An antenna is supplied with the module for a longer transmission distance.
Product typeBluetooth module
Bluetooth version5.0
Bluetooth chipQualcomm CSR8675
DAC chipPCM5102A
Supported Bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD
OutputAnalog output on 3-pin connector
Output level2.1V max
SNR112dB
THD-93dB
Supply voltage9-20V DC
Dimensions62.5 x 59mm
Weight35g
Package1x Bluetooth Module
1x Bluetooth antenna
OutputPCB Connector
This small Bluetooth 5.0 reception module is based on a Qualcomm CSR8675 chip and a PCM5102A DAC for the digital/analog conversion of the audio...
