Bluetooth 5.0 Receiver Board QCC5125 LDAC aptX HD aptX Adaptive to I2S
This Bluetooth 5.0 receiver module is equipped with the new Qualcomm QCC5125 chip, which supports the high-quality transmission codecs LDAC and aptX HD, as well as aptX Adaptive, a technology that automatically finds the best combination of quality and stability. This means that the data rate is adapted to the quality of the connection between the transmitter and receiver.
Reference : 15375
32,90 €tax incl.
27,42 € tax excl.
Bluetooth Board
Module Récepteur Bluetooth 5.0 QCC5125 LDAC aptX HD aptX Adaptive vers I2S
This Bluetooth 5.0 receiver module is equipped with the new Qualcomm QCC5125 chip, which supports the high-quality transmission codecs LDAC and aptX HD, as well as aptX Adaptive, a technology that automatically finds the best combination of quality and stability. This means that the data rate is adapted to the quality of the connection between the transmitter and receiver. The output is in I2S on solder pads. The module is delivered with an antenna, to ensure a stable and fast transmission.
The pin code for the module is: 0123.
Product typeBluetooth receiver board
Bluetooth chipQualcomm QCC5125
Bluetooth version5.0
OutputI2S (on solder pads)
Supported Bluetooth codecsaptX, aptX HD, aptX Adaptive
Power supply5V DC on solder pads (sold separately)
Dimensions38 x 24mm
Input
  • Solder pad
Output
  • Solder pad
2 reviews
USB Communication
Search for SJR-BTM525, this is the name of the blue module and find module pinout
To enable USB communication you need to solder "USB_DP" and "USB_DM" to your preferred connector and you must solder/connect "VCHG" to your power voltage, without this the USB is disabled.
I connected "VCHG" to +5V currently working but not sure, maybe you should use +3.3V
PLEASE REFER TO CHIP DATASHEET (not module) TO AVOID ANY DAMAGE!!!
No-one takes responsibility for how you modded this module ;)
This review has been posted for Bluetooth 5.0 Receiver Board QCC5125 LDAC aptX HD aptX Adaptive to I2S
Defaualt code is "0123"
lot of product here missing some useful description
This Bluetooth 5.0 receiver module is equipped with the new Qualcomm QCC5125 chip, which supports the high-quality transmission codecs LDAC and...
