QCC5125 aptX HD LDAC DAC ES9023
This Bluetooth 5.1 receiver module is based on the use of a Qualcomm QCC5125 chip, which supports the high-resolution transmission codecs aptX, aptX HD and LDAC for quality wireless sound reproduction. It will allow you, in a DIY audio design, to equip your device with a convenient Bluetooth reception to broadcast your music remotely.
The module also includes an ES9023 DAC, which converts the digital signal into analog. Thanks to its HyperStream architecture, it allows a clear and detailed sound reproduction, notably thanks to its jitter elimination technology.
1 | Left channel analog audio input |
2 | Right channel analog audio input |
3 | Left channel analog audio output |
4 | Right channel analog audio output |
5 | GND |
6 | If DC power supply : 5V / If AC power supply : Leave empty |
7 | AC 7-12V power supply |
The module can be supplied with either AC or DC power. AC power supply provides better performance. In case of DC power supply, please remove the LM7805 voltage regulator beforehand.
Product type | Bluetooth receiver board |
Bluetooth version | 5.1 |
Supported Bluetooth codecs | aptX, aptX HD, LDAC |
Inputs | Bluetooth 1x Analog |
Output | 1x Analog |
Bluetooth chip | Qualcomm QCC5125 |
DAC chip | ES9023 |
Dimensions | 52 x 35mm |
