Ultra facile a mettre en oeuvre. Utilisé avec un DAC Sabre. Bonne restitution du son.
This module provides your audio installation with Bluetooth 4.2 connectivity. Its embed technology Apt-X allows it to receive audio streams with an almost insignificant loss rate. This encoding / decoding technology is automatic, which means the card will automatically adjust the compression transfer depending on the audio file type. This minimizes the loss to an almost imperceptible level of FLAC.
Conversely, when an already compressed audio file is submitted, this Bluetooth Module automatically detects and adapts to not to apply additional compression. MP3 files less than 350kb / s will thus be transmitted as is without any treatment so as not to denature the audio definition.
The Bluetooth module is equipped with an I2S output with a 100 mHz fixed MLCK (compatible ESS 9018, 9028, 9038), so it can connect directly to a Sabre DAC equiped with this kind of input in order to enjoy both wireless connectivity and high-quality conversion.
The output MCK (MasterClock) supplied with 5V enables it to significantly reduce jitter for a result well above the ordinary Bluetooth connectivity.
Type | bluetooth receiver |
Version | 4.2 |
Chip | CSR64215 |
Input | Bluetooth (wireless) |
Output | I2S (MLCK fixed at 100mhz) |
Alimentation | DC 5V |
Dimensions | L: 32 x H : 70 x D : 3.5 mm |
Weight | 10 g |
spacing | 22 mm x 60 mm |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
