HYPEX FUSION REMOTE KIT IR Receiver Module for Hypex FusionAMP Amplifier
All plate amplifier modules Hypex FusionAMP can be improved with this Fusion Remote Kit. It is composed of an IR receiver module, a two-color LED, a plexiglass panel, double-sided adhesive and the cables required to install the module.
Reference : 13533
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 22-04-2025.
Hypex Fusion Remote Kit
Récepteur IR pour module amplificateur Hypex FusionAMP
Hypex Fusion Remote Kit Récepteur IR pour module amplificateur Hypex FusionAMP
All plate amplifier modules Hypex FusionAMP can be improved with this Fusion Remote Kit. It is composed of an IR receiver module, a two-color LED, a plexiglass panel, double-sided adhesive and the cables required to install the module. The kit can be mounted inside or outside the body of your speaker. It will allow you to use an IR remote control to remotely control your system (remote control sold separately).
Note: The IR module can be used on a device in master mode to use the Hypex remote control. It can also be used on a device in slave mode, but in this case the IR functionality. The green LED will then display the ON or OFF status of the device and the red LED will indicate the protection.
Product typeIR Receiver for Hypex FusionAMP
Package1x PCB with IR Receiver and bi-color LED
1x Plexiglass panel
Double side adhesive
Mounting cables
InputIR
OutputNC
All plate amplifier modules Hypex FusionAMP can be improved with this Fusion Remote Kit. It is composed of an IR receiver module, a two-color LED,...
