LHY AUDIO Bluetooth 5.1 Receiver QCC5125 aptX HD LDAC 24bit / 96kHz
This Bluetooth 5.1 receiver module is based on the use of a Qualcomm QCC5125 chip, which supports the high-resolution transmission codecs aptX, aptX HD and LDAC for quality wireless sound reproduction. It will allow you, in a DIY audio design, to equip your device with a convenient Bluetooth reception to broadcast your music remotely.
Reference : 17559
26,90 €tax incl.
22,42 € tax excl.
Shipping date: 16-04-2025.
LHY AUDIO Bluetooth RECEIVER 5.1
LHY AUDIO Récepteur Bluetooth 5.1 QCC5125 aptX HD LDAC 24bit / 96kHz
This Bluetooth 5.1 receiver module is based on the use of a Qualcomm QCC5125 chip, which supports the aptX, aptX HD and LDAC high-resolution transmission codecs for quality wireless sound reproduction. It will thus allow you, in a DIY audio design, to equip your device with a practical Bluetooth reception to broadcast your music remotely.
The module also has an I2S signal output and a USB TYPE-C for power.
1Bluetooth Antenna
2Power DC 5v
3Input USB-C / Power supply USB-C
4Bluetooth Qualcomm QCC5125 chip
5Play/pause button
6Next/VOL+ Button
7Previous/VOL- Button
8I2S Output
I2S Pin out
I2S Pin out
SpEcifications
Product typeBluetooth receiver module
Bluetooth version5.1
Supported Bluetooth CodecsaptX, aptX HD, LDAC, ACC
InputsBluetooth
1x USB-C (Input and power supply)
OutputI2S
Bluetooth chipQualcomm QCC5125
Power supplyUSB-C (Input and power supply)
5V DC external power input pin
Power consumption5-10 mA
Dimensions64 x 31,5 x 1,6 mm
Weight24g
OutputI2S
This Bluetooth 5.1 receiver module is based on the use of a Qualcomm QCC5125 chip, which supports the high-resolution transmission codecs aptX,...
