LQSC Bluetooth 4.2 Stereo Receiver Module 2x Jack 3.5mm
This small Bluetooth 4.2 receiver module will allow you, within the framework of a DIY project, to take advantage of a wireless connectivity simple and fast of use. It becomes possible to broadcast your music remotely, directly from a smartphone or a tablet for example.
Reference : 17377
10,90 €tax incl.
9,08 € tax excl.
Shipping date: 07-02-2025.
LQSC Bluetooth Receiver Module
LQSC Module récepteur Bluetooth 4.2 Stéréo
This small Bluetooth 4.2 receiver module will allow you, within the framework of a DIY project, to take advantage of a wireless connectivity simple and fast of use. It becomes possible to broadcast your music remotely, directly from a smartphone or a tablet for example. In addition to this connectivity, the module embeds in input and output Jack 3.5mm as well as two XH2.54mm 3 pins connectors.
1Analog audio output
2Jack 3.5mm output
3Jack 3.5mm input
4Micro USB 5VDC power input
55-12VDC power input
6Analog audio input
7Bluetooth antenna
8U.FL connector for external Bluetooth antenna
Product typeBluetooth receiver module
InputsBluetooth
1* Jack 3.5mm
1* Analog input on XH 2.54mm 3 pins connector
Sorties1* Jack 3.5mm
1* Analog output on XH 2.54mm 3 pins connector
Bluetooth version4.2
Bluetooth nameLQSC_BT
Operating temperature range-40°C to 85°C
External antenna connectorU.FL format (antenna sold separately)
Supply voltage5-12VDC on PCB connector OR 5VDC via Micro SD (power supply sold separately)
Dimensions55*32*9mm
Weight20g
Package1* Bluetooth receiver module
2* XH2.54mm 3 pins cable
InputJack 3.5mm
InputXH 2.54mm
OutputJack 3.5mm
OutputXH 2.54mm
This small Bluetooth 4.2 receiver module will allow you, within the framework of a DIY project, to take advantage of a wireless connectivity simple...
