Bluetooth Receiver Module 4.2 CSR64215 APTX
A compact Bluetooth receiver module. Can fit into the analog input of an amplifier.
Reference : 12665
19,90 €tax incl.
16,58 € tax excl.
Module récepteur Bluetooth
Bluetooth 4.2 CSR64215 aptX avec Antenne
Module récepteur Bluetooth 4.2 CSR64215 aptX avec Antenne
This Bluetooth 4.2 module is equipped with aptX technology that allows it to receive audio streams with an almost insignificant loss rate. This encoding/decoding technology is intelligent, meaning that data compression automatically adapts to the type of audio file being played, minimizing loss to an almost imperceptible level on FLAC. Conversely, the module will detect by itself when an audio file is already compressed so as not to apply additional compression to it. MP3 files < 350kb/s will therefore be transmitted as is without any processing in order to preserve their definition.
This feature makes this audio module a versatile solution that can be adapted for home use to add wireless connectivity to a fixed audio installation. With its small size, it will also fit into smaller environments such as a car audio system so that all passengers can share their music from their smartphones or tablets. The CSR64215 chip natively has a decoding function. The digital-to-analog conversion is therefore carried out directly upon receipt of the signal. It is therefore not necessary to add a DAC module, which saves a lot of space.
Easy integration into your audio system
This Bluetooth module CSRA64215 has one analog input and one analog output. It can therefore be installed directly between the RCA plugs and the analog inputs of an amplifier. The change of analog / bluetooth source is done automatically according to the pairing status. (If a mobile phone is paired, the analog input will automatically be transferred) and vice versa.
On the wireless side, the CSR64215 chip provides Bluetooth 4.2 connectivity, which provides sufficient throughput for audiophile quality. This Bluetooth chip is mainly natively designed to operate at high audio speeds. This makes it an ideal solution for ambitious audio installations.
Mounting diagram
Product typeBluetooth receiver board
Integrated DAC functionYes
Version4.2
InputsWireless
Analog
OutputAnalog
Genral
Dimensions58 x 37.5 x 26.5mm
Height with antenna44mm
Removable antennaOui
OutputSolder pad
Ecxellent
À première vue, ce module a l'air bas de gamme mais détrompez vous la qualitée est la !
Le seul point à noter est qu'il y a qu'un seul trou de fixation !
Pas de problème pour le coupler à n'importe quel appareil BT, pas de souffle ni de perte de connexion, antenne externe idéal pour les boîtiers métalliques !
Désormais ce module sera intégré sur les prochain amplis de ma fabrication !
 (3)
This review has been posted for Bluetooth 4.2 Receiver Module CSR64215 aptX with Antenna
