TINYSINE AUDIOB I2S Bluetooth Receiver Module
This Tinysine AudioB I2S Bluetooth receiver module is based on a Qualcomm QCC3008 chip. This enables it to support sampling rates of up to 16bit 48kHz and reliable, stable transmission via the aptX codec. It has a U-FL connector for connecting an external 2.4G antenna, and output is via I2S.
Reference : 20053
12,90 €tax incl.
10,75 € tax excl.
Shipping date: 22-04-2025.
Tinysine AudioB I2S Bluetooth 5.0 Receiver Module QCC3008 aptX U.FL
Tinysine AudioB I2S
This Tinysine AudioB I2S Bluetooth receiver module is based on a Qualcomm QCC3008 chip. This enables it to support sampling rates of up to 16bit 48kHz and reliable, stable transmission via the aptX codec. It has a U.FL connector for connecting an external 2.4G antenna, and output is via I2S. The module features two sets of 10 pins, each spaced 2mm apart from the others for easy integration into many types of DIY projects such as a Bluetooth amplifier or DAC.
Module pin correspondence table
Mounting diagram
Mounting diagram
Module dimensions
Technical charcateristics
Product typeBluetooth receiver module
Bluetooth chipQCC3008
Bluetooth versionBluetooth 5.0
OutputI2S (left justified, 1bit delay)
Supported sample rates16bit 48kHz
Supported Bluetooth codecsaptX, SBC, AAC
Power consumption5mA @ 5V
Supported Bluetooth profilesHFP V1.6
HSP V1.2
A2DP V1.2
AVRCP v1.4
Smartphone application support
Package1x Tinysine AudioB I2S Bluetooth Receiver Module
OutputI2S
TINYSINE AUDIOB I2S Bluetooth 5.0 Receiver Module QCC3008 aptX U.FL
This Tinysine AudioB I2S Bluetooth receiver module is based on a Qualcomm QCC3008 chip. This enables it to support sampling rates of up to 16bit...
