TINYSINE AUDIO-B PLUS Bluetooth 4.0 Receiver Module
If you want to build a Bluetooth amplifier simply and stream your music from your smartphone, then the TinySine Bluetooth AudioB Plus receiver module is an excellent choice. It is indeed a Bluetooth 4.0 stereo receiver based on a CSRA64215 chip.
Reference : 14555
14,95 €tax incl.
12,46 € tax excl.
Shipping date: 22-04-2025.
TinySine Audio-B Plus
TinySine AudioB Plus Module Récepteur Bluetooth aptX SMA
If you want to build a Bluetooth amplifier simply and stream your music from your smartphone, then the TinySine Bluetooth AudioB Plus receiver module is an excellent choice. It is indeed a Bluetooth 4.0 stereo receiver based on a CSRA64215 chip. The module has two sets of 10 pins, each pin spaced 2mm from the others for easy integration into your project.
In addition, Bluetooth version 4.0 will allow you to achieve very good data transfer rates and the aptX protocol supported by the chip ensures both better signal stability and better synchronization. All this contributes to a much better sound reproduction.
Correspondence table of the module pins
Schema: Unbalanced signal output
Schema: Unbalanced signal output to headphones or small speakers
Schema: Differential signal output
Bluetooth version4.0
Consumption5mA @ 5V
Supported Bluetooth profilesHFP V1.6
HSP V1.2
A2DP V1.2
AVRCP V1.4
Supports smartphone applications-
OutputSolder pad
très bon produit
simple et conforme à la description. qualité audio appréciable
This review has been posted for TINYSINE AUDIO-B PLUS Bluetooth 4.0 Receiver Module
If you want to build a Bluetooth amplifier simply and stream your music from your smartphone, then the TinySine Bluetooth AudioB Plus receiver...
