TINYSINE AUDIO-B PLUS Bluetooth 4.2 Receiver Module aptX SMA
If you want to build a Bluetooth amplifier simply and stream your music from your smartphone, then the TinySine Bluetooth AudioB Plus receiver module is an excellent choice. It is indeed a Bluetooth 4.2 stereo receiver based on a CSRA64215 chip.
4.0 / 5
Reference : 12872
16,90 €tax incl.
14,08 € tax excl.
Shipping date: 22-04-2025.
TinySine Audio-B Plus
Bluetooth 4.2 Receiver aptX SMA
TinySine AudioB Plus Module Récepteur Bluetooth aptX SMA
If you want to build a Bluetooth amplifier simply and stream your music from your smartphone, then the TinySine Bluetooth AudioB Plus receiver module is an excellent choice. It is indeed a Bluetooth 4.2 stereo receiver based on a CSRA64215 chip. The module has two sets of 10 pins, each pin spaced 2mm from the others for easy integration into your project. In addition, an SMA port will allow you to connect a 2.4G antenna for longer operating distance.
In addition, Bluetooth version 4.0 will allow you to achieve very good data transfer rates and the aptX protocol supported by the chip ensures both better signal stability and better synchronization. All this contributes to a much better sound reproduction.
Correspondence table of the module pins
Schema: Unbalanced signal output
Schema: Unbalanced signal output to headphones or small speakers
Schema: Differential signal output
Bluetooth version4.2
Supported protocolsaptX
Antenna connectorSMA
Consumption5mA @ 5V
Supported Bluetooth profilesHFP V1.6
HSP V1.2
A2DP V1.2
AVRCP V1.4
Supports smartphone applications-
OutputPCB Connector
Is working fine, but not the advertised chip
The module seems to work fine, but the description is not correct. It says it has the CSRA64215 Bluetooth 4.2 chip, and the one I received had the QCC3008 Bluetooth 5.0 chip on it.
This review has been posted for TINYSINE AUDIO-B PLUS Bluetooth 4.2 Receiver Module aptX SMA
If you want to build a Bluetooth amplifier simply and stream your music from your smartphone, then the TinySine Bluetooth AudioB Plus receiver...
