TINYSINE CSR USB-SPI Bluetooth CSR Chip Programmer
This TinySine USB-SPI CSR card will allow you to program your CSR Bluetooth chips. This module has a much better download speed than a parallel port programmer. This programmer supports all CSR debug tools (BlueFlash, PSTOOL, BlueTest3, BlueLbab). You can also change the Bluetooth name of your Bluetooth receivers or amplifiers.
Reference : 12867
27,90 €tax incl.
23,25 € tax excl.
Shipping date: 21-07-2026.
TinySine CSR USB-SPI
Programmateur pour Puces Bluetooth CSR
This USB-SPI CSR card will allow you to program your CSR Bluetooth chips. This module has a much better download speed than a parallel port programmer. This programmer supports all CSR debug tools (BlueFlash, PSTOOL, BlueTest3, BlueLbab). You can also change the Bluetooth name of your Bluetooth receivers or amplifiers.
Supported CSR chip :
  • BC2 Series (example : BC215159A, etc.)
  • BC3 Series (example : BC31A223, bC358239A, etc.)
  • BC4 Series (example : BC413159A06, BC417143B, BC419143A, etc.)
  • BC5 Series (example : BC57F687, BC57E687, BC57H687C, etc.)
  • BC6 Series (example : BC6110, BC6130, CSR6030, BC6888, etc.)
  • BC7 Series (example : BC7820, BC7830, etc.)
  • BC8 Series (example : CSR8610, CSR8620, CSR8645, CSR8670, etc.)
  • BLE Series (example : CSR1000, CSR1001, etc.)
This CSR programmer also allows to program the QCC3008 Bluetooth chips, thanks to a different software available here : ADK QCC3000x.
Double output voltage3.3V
1.8V
SPI logic levelPossibility to choose between 1.8V or 3.3V (for 3.3V connect the pin 3.3V to the pin GND)
ProtectionShort circuit
InputPCB Connector
OutputPCB Connector
It works
No problems, I could recommend.
This review has been posted for TINYSINE CSR USB-SPI Bluetooth CSR Chip Programmer
This TinySine USB-SPI CSR card will allow you to program your CSR Bluetooth chips. This module has a much better download speed than a parallel...
