TINYSINE PCB-I2S PCB for Audio-B Bluetooth I2S Receiver
This PCB allows easier mounting of Bluetooth modules to I2S TinySine Audio-B I2S and Audio-B I2S SMA. Once assembled, the Audio-B module and this PCB-I2S will provide you with an easy-to-wire I2S output and an analog and bluetooth input.
Reference : 13326
1,90 €tax incl.
1,58 € tax excl.
Shipping date: 16-04-2025.
TinySine PCB-I2S
TINYSINE PCB-I2S PCB pour Récepteur Bluetooth I2S
This PCB allows easier mounting of Bluetooth modules to I2S TinySine Audio-B I2S and Audio-B I2S SMA. Once assembled, the Audio-B module and this PCB-I2S will provide you with an easy to wire I2S output (GND, BCK, LRCK, DATA), contacts for 5V power supply, to add an analog input and finally to add an input selector (select Bluetooth or analog input).
Note: The PCB-I2S is sold alone. The Audio-B I2S and Audio-B I2S SMA modules are sold separately.
Note 2 : We strongly recommend that you add Strip Connectors between the PCB-I2S and your Audio-B module for a cleaner mounting.
Diagram
TinySine PCB-I2S PCB pour récepteur bluetooth i2s
1Analog input
2Sélecteur de source
3Alimentation
4Sortie I2S
5Connecteur module Bluetooth
Mounting direction PCB + Audio-B
TinySine PCB pour Audio-B
Product typePCB for Audio-B Bluetooth I2S Receiver
InputsBluetooth
Analog
OutputI2S (GND, BKC, LRCK, DATA)
Power supply5V
Dimensions29.2 x 26.5mm
Fixation holes spacing20mm
OutputI2S
This PCB allows easier mounting of Bluetooth modules to I2S TinySine Audio-B I2S and Audio-B I2S SMA. Once assembled, the Audio-B module and this...
