TINYSINE TC2050-IDC-NL Connection Cable for Programmer and Debugger
This TinySine TC2050-IDC-NL cable will allow you to quickly and easily connect a debugger, programmer or other test equipment to your PCB.
Reference : 12868
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 22-04-2025.
Connection cable for programmer and debugger
câble pour debugger et programmateur
This TC2050-IDC-NL cable will allow you to quickly and easily connect a debugger, programmer or other test equipment to your PCB.
The cable uses a special design (patent pending) for its connector allowing to do without a programming header or other adapter on each PCB. Instead, the cable offers a connector with spring-loaded pins to fit the different connectors on your PCBs.
To summarize, the cable has a TC2050-NL 10-pin connector on the one hand and a standard 0.1" grounding connector on the other. It will therefore be usable with most MCU, FPGA and JTAG.
This cable necessarily requires the use of the CSR TinySine CSR USB-SPI. programmer for chips.
InputNC
OutputNC
Length (m)N/A
ShieldingNo
Section (mm²)N/A
ConnectorN/A
