TINYSINE TSA5001 Bluetooth 5.3 I2S Transmitter Module aptX HD
The Tinysine TSA5001 is a compact Bluetooth 5.3 transmitter module with I2S input. It can be used to connect an audio player with an I2S digital output to an amplifier with Bluetooth wireless reception.
Reference : 18399
16,90 €tax incl.
14,08 € tax excl.
Shipping date: 23-04-2025.
TinySine TSA5001
Tinysine TSA5001 Module émetteur Bluetooth 5.3 I2S aptX HD
No driver is required. Simply supply the module with an I2S signal and switch it on. It will automatically search for and connect to your Bluetooth receiver.
The TSA5001 is an I2S slave module. Please ensure that your I2S output device is an I2S master module.
Tinysine TSA7551B Amplificateur Mono TDA7498E DSP ADAU1701 Bluetooth 5.0 aptX 170W 4 OhmTinysine TSA5001 Module émetteur Bluetooth 5.3 I2S aptX HD
1U.FL antenna interface
2I2S input
35V power input
4Pairing button connector
Pinout I2S input connector:
  • SD
  • LRCK
  • BCLK
  • MCLK (not used)
  • GND
Pairing button (sold separately) :
  • Long press 3s to activate pairing
  • Long press 5s to reset pairing
How do I pair the module?
  1. Keep your TSA5001 Bluetooth transmitter and Bluetooth receiver within 5m of each other. Make sure the antenna (sold separately) is installed..
  2. Switch on your Bluetooth receiver and keep it in pairing mode.
  3. Power up the TSA5001 transmitter module and it will automatically reconnect to the last device to which it was paired. The blue LED flashes slowly.
  4. If reconnection to the last registered device fails, the module will attempt to connect to a nearby Bluetooth device. The LED flashes rapidly.
  5. Once connected, the blue LED remains lit.
Product typeBluetooth transmitter module
Bluetooth version5.3
InputI2S
OutputBluetooth 5.3
Supported Bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD
Bluetooth protocolA2DP
Dimensions36*28*9mm
Weight10g
InputPCB Connector
OutputPCB Connector
The Tinysine TSA5001 is a compact Bluetooth 5.3 transmitter module with I2S input. It can be used to connect an audio player with an I2S digital...
