TINYSINE TSA6015 Bluetooth 4.0 Receiver Board CSR8635 wih Microphone Input
This Bluetooth receiver integrates both a 3.5mm jack connector at the output and a second 3.5mm jack input for connecting a microphone. It is thus possible to use this module to stream your music from your smartphone but also to answer incoming calls from your phone.
Reference : 13637
17,90 €tax incl.
14,92 € tax excl.
Shipping date: 22-04-2025.
TinySine TSA6015
Bluetooth 4.0 Receiver Board wih Microphone Input
TinySine TSA6015 Récepteur Audio Bluetooth avec Entrée Micro
This Bluetooth receiver integrates both a 3.5mm jack connector at the output and a second 3.5mm jack input for connecting a microphone. It is thus possible to use this module to stream your music from your smartphone but also to answer incoming calls from your phone. A button on the module allows you to answer when you receive a call.
Only the Bluetooth receiver module TSA6015 is provided. The other elements are to be purchased separately.
How to set TinySine boards in TWS mode ?
Product typeBluetooth receiver
OutputJack 3.5mm (Stereo)
InputJack 3.5mm (Microphone)
Bluetooth version / chip4.0 / CSR8635
Max transmission distance10-15m
Power supply5VDC via Micro USB (Sold separately)
Dimensions42 x 32 x 11mm
InputJack 3.5mm
OutputJack 3.5mm
Très bon produit, fonctionne parfaitement.
M'a permis de connecter une casque audio et microphone via bluetooth à mon téléphone. Le système dispose d'un bouton permettant de faire play/pause pour la musique diffusée en bluetooth ou permet de décrocher quand on reçoit un appel (la sonnerie s'entend par la sortie audio).
This review has been posted for TINYSINE TSA6015 Bluetooth 4.0 Receiver Board CSR8635 wih Microphone Input
This Bluetooth receiver integrates both a 3.5mm jack connector at the output and a second 3.5mm jack input for connecting a microphone. It is thus...
