TINYSINE TSA6016 Bluetooth 5.0 aptX Receiver Board wih Microphone Input
This Bluetooth 5.0 aptX receiver integrates both a 3.5mm jack connector at the output and a second 3.5mm jack input for connecting a microphone. It is thus possible to use this module to stream your music from your smartphone but also to answer incoming calls from your phone.
Reference : 13638
21,90 €tax incl.
18,25 € tax excl.
TinySine TSA6016
TinySine TSA6015 Récepteur Audio Bluetooth avec Entrée Micro
This Bluetooth receiver integrates both a 3.5mm jack connector at the output and a second 3.5mm jack input for connecting a microphone. It is thus possible to use this module to stream your music from your smartphone but also to answer incoming calls from your phone. A button on the module allows you to answer when you receive a call. In addition, the integrated Bluetooth chip supports Bluetooth version 5.0 as well as aptX. The module thus ensures increased transmission rates and stability.
Only the Bluetooth receiver module TSA6016 is provided. The other elements are to be purchased separately.
Set the TinySine boards in TWS mode
Product typeaptX Bluetooth receiver
OutputJack 3.5mm (Stereo)
InputJack 3.5mm (Microphone)
Bluetooth version5.0
aptX SupportYes
Max transmission distance10-15m
Power supply5VDC via Micro USB (sold separately)
Dimensions42 x 32 x 11mm
InputJack 3.5mm
OutputJack 3.5mm
Best Bluetooth receiver ever!
I have tried many Bluetooth receivers over the years, this one is the best! The sound quality is as rich as cable quality, and also no interferences during phone calls. Finally I found a prime quality Bluetooth to use in my car.
This review has been posted for TINYSINE TSA6016 Bluetooth 5.0 aptX Receiver Board wih Microphone Input
This Bluetooth 5.0 aptX receiver integrates both a 3.5mm jack connector at the output and a second 3.5mm jack input for connecting a microphone. It...
