TINYSINE TSA6175 Bluetooth 5.0 Receiver Board Multipoint
Blutooth multipoint 5.0 standard module to analog stereo output on 3.5mm jack. Power easily via micro-USB DC 5V
Reference : 13886
26,90 €tax incl.
22,42 € tax excl.
Shipping date: 23-04-2025.
TSA6175 bluEtooth multipoint 5.0 receiver module
This module is a Bluetooth receiver equipped with an audio output jack 3.5. Once paired with a Bluetooth audio source, it is able to retrieve the stream and decode to restore an analog audio signal.
This type of device is particularly useful for integrating an audio source that does not have native connectivity without wire audio system based partly or mainly on the technology. It is also an inexpensive solution and respectful signal to limit the size of the cables in the living rooms.
With its ease of integration and power supply, the module will respond to cases many and varied. Improved device, adding connectivity, replacement receiver modules, integration of vehicle interior ... etc.
Multipoint
multipoint diagram illustration
This receptor is multipoint, that is to say, it can connect to multiple devices simultaneously, observing some prerequisites.
If several similar modules are used simultaneously, one can make master receiver office. The master receiver then becomes the source of other TSA6175 modules that can synchronize the flow of several audio outputs.
Multipoint technology is highly appreciated in that it allows both to combine and split the audio stream at will and especially to connect and disconnect devices on the fly without affecting the operation of the master system.
basic usage pattern
TypeBluetooth receiver
Dimensions44x38x11mm
StandardBluetooth 5.0
SupportQualcomm audio CVC
Qualcomm TrueWireless
Canalsx2 (stereo)
Range10-15m
Power supply5v DC (micro USB)
OutputJack 3.5mm
