TINYSINE TSA6178 U.FL Bluetooth 5.0 Receiver Board aptX SPDIF Coaxial Output
This Bluetooth 5.0 receiver module TinySine TSA6178 allows you to broadcast your music remotely, for example from a smartphone or a tablet. The output is in SPDIF coaxial and the module can be connected to your existing audio system. Bluetooth reception is provided by an AudioB Digi module and supports the high-quality aptX transmission codec. The TSA6178 also provides a line input on a 3.5mm jack.
Reference : 16414
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 25-04-2025.
TinySine TSA6178 u.fl
TinySine TSA6178 Module Récepteur Bluetooth 5.0 aptX Sortie SPDIF Coaxiale
The Bluetooth antenna of the TSA6178 is sold separately. This one is connected to the UF.L. connector.
The TSA6178 automatically detects the incoming signal on Bluetooth and on the line input. Bluetooth has a higher priority. When no stream is received via Bluetooth, then the TSA6178 automatically switches to the line input.
Product typeBluetooth receiver board
InputsBluetooth 5.0
1x Jack 3.5mm line input
Output1x Coaxial
Supported Bluetooth codecaptX
Supported technologiesQualcomm cVc
Qualcomm TrueWireless
Max transmission distance10-15m
Power supply5VDC via Micro USB (not included)
Dimensions180 x 33 x 54mm
InputJack 3.5mm
OutputCoaxial SPDIF
This Bluetooth 5.0 receiver module TinySine TSA6178 allows you to broadcast your music remotely, for example from a smartphone or a tablet. The...
