1MII LAVAUDIO B03+ Receiver Transmitter Bluetooth 5.0 aptX HD CSR8675 ADC DAC
The 1Mii B03+ is an extremely versatile and high-performance Bluetooth transmitter and receiver at an affordable price. Its intelligent and careful design allows it to ensure high quality sound reproduction, notably thanks to a high-performance Bluetooth chip and a conversion stage based on a DAC proven and recognized by audiophiles.
Reference : 15827
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 02-04-2025.
1Mii B03+
1Mii B03+ Récepteur Émetteur Bluetooth 5.0 aptX HD CSR8675
1Mii B03pro Récepteur Émetteur Bluetooth 5.0 aptX HD CSR8675
No Delay
aptX Low Latency technology eliminates the delay when transmitting audio over Bluetooth for perfectly synchronized listening. The Dual Link function allows it to be broadcast over two headsets or two speakers in a fully synchronized manner.
High Definition Audio
With support for the aptX HD Bluetooth transmission codec, the 1Mii B03+ is capable of delivering sound quality at least equal to that of a CD, wirelessly.
Extended transmission distances
Using Bluetooth Class 1 technology and integrating two antennas, the B03+ can reach transmission/reception distances of up to 30m (without obstacles).
LED Screen
The 1MII B03+ is equipped with an LED display. It allows to clearly display the detected and connected Bluetooth devices as well as other information such as the volume level.
1MII B03+ Récepteur émetteur Bluetooth 5.0 aptX HD CSR8675 ADC DAC
Bluetooth 5.0
At the heart of the 1Mii B03+ is a Qualcomm CSR8675 Bluetooth 5.0 chipset, a high-performance solution designed to ensure high-quality audio reproduction. It ensures clean and stable signal transmission and reception.
Additional connections
The B03+, in addition to its Bluetooth connectivity, offers a 3.5mm jack and Toslink Optics as inputs and outputs.
3 Operating modes
Versatile, the 1Mii B03+ can be used in 3 different modes, in order to adapt to everyone's needs: receive, transmit and bypass.
Transmitter mode
The 1Mii B03+ can be used as a Bluetooth transmitter. In this mode, you can transmit an audio stream to an audio device, TV, AV receiver, headphones, speakers or any other audio source device with Bluetooth connectivity.
Receiver mode
In receiver mode, the B03+ can receive a Bluetooth audio stream from a connected device, such as a smartphone, tablet or computer.
Bypass mode
Finally, the bypass mode connects an input directly to an output, with the receive and transmit functions disabled. Bypass mode allows the device to be used in DAC (Digital to Analog Converter) mode, or ADC (Analog to Digital Converter) mode.
1MII B03+ Récepteur Bluetooth 5.0 aptX HD CSR8675 ADC DAC
Product typeBluetooth Transmitter / Receiver
InputsBluetooth 5.0
1x Optical Toslink
1x Jack 3.5mm
OutputsBluetooth 5.0
1x Optical Toslink
1x Jack 3.5mm
Bluetooth chipQualcomm CSR8675
DAC Chip-
Bluetooth version5.0
Supported Bluetooth profilesA2DP
AVRCP
Supported Bluetooth codecsSBC
AAC
aptX
aptX LL
aptX HD
Max transmission distanceObstacle-free: 30m
Package1x 1Mii B03+
1x USB-A to Micro USB cable
1x Jack 3.5mm to RCA cable
1x Jack 3.5mm cable
1x Optical cable
1x Power supply
InputJack 3.5mm
OutputOptical Toslink
OutputBluetooth
OutputJack 3.5mm
DAC / ADC ChipES9018Q2C
Supported Bluetooth codecsAAC
The 1Mii B03+ is an extremely versatile and high-performance Bluetooth transmitter and receiver at an affordable price. Its intelligent and careful...
