Son d’enfer. Je redécouvre mes morceaux et albums MP3 320Kb
+ Plus de coupure ou de saut de la connexion (Bluetooth 5.0) et plus de ralentissement bizarres pouvant survenir pendant l'ecoute
Heureux !
Bluetooth 5.0 Receiver aptX LDAC CSR8675 DAC ES9018K2M
The 1Mii DS200Pro is a compact and powerful Bluetooth 5.0 receiver, using a Qualcomm CSR8675 Bluetooth chip. This one is compatible with the codecs of high resolution transmission like the aptX, the aptX LL, the aptX HD or the LDAC for a listening of great quality, even in wireless.
The conversion stage is entrusted to an ESS ES9018K2M DAC chip, in charge of processing and converting digital audio data into analog. The latter supports high sampling rates, up to PCM 32bit 384kHz, and ensures excellent audio performance, with a dynamic range of 127dB and a THD+N of -120dB.
On the connectivity side, there are RCA output as well as a digital optical output for maximum compatibility with your current audio system.
Product type | Bluetooth reception |
Bluetooth chip | Qualcomm CSR8675 |
Bluetooth version | 5.0 |
Supported Bluetooth codecs | AAC, SBC, aptX, aptX HD, aptX LL, LDAC |
DAC Chip | ESS ES9018K2M |
Outputs | 1x Stereo RCA 1x Optical Toslink |
Dynamic range | 127dB |
THD+N | -120dB |
Dimensions | 105 x 90 x 26mm |
Color | Black |
Package | 1x 1Mii DS200Pro 1x Power cable 1x Female Jack 3.5mm to Male RCA cable 1x Optical cable 1x RCA Cable 4x Rubber feet |
Input | Bluetooth |
Output | Optical Toslink |
Output | RCA |
DAC / ADC Chip | ES9018 |
Color | Black |
Transmission / Reception protocol | Bluetooth |
Supported Bluetooth codecs | SBC |
Supported Bluetooth codecs | aptX |
Supported Bluetooth codecs | aptX LL |
Supported Bluetooth codecs | AAC |
Supported Bluetooth codecs | aptX HD |
Supported Bluetooth codecs | LDAC |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Francois L.
Mathieu J.
