1MII LAVAUDIO B03PRO Receiver Transmitter Bluetooth 5.0 aptX HD CSR8675 ADC DAC ES9018
The 1Mii B03Pro is an extremely versatile and high-performance Bluetooth transmitter and receiver at an affordable price. Its intelligent and careful design allows it to ensure high quality sound reproduction, notably thanks to a high-performance Bluetooth chip and a conversion stage based on a DAC proven and recognized by audiophiles.
Reference : 15114
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 22-04-2025.
1Mii B03Pro
Receiver Transmitter Bluetooth 5.0 aptX HD CSR8675 ES9018
1Mii B03pro Récepteur Émetteur Bluetooth 5.0 aptX HD CSR8675 ES9018
No Delay
aptX Low Latency technology eliminates the delay when transmitting audio over Bluetooth for perfectly synchronized listening. The Dual Link function allows it to be broadcast over two headsets or two speakers in a fully synchronized manner.
High Definition Audio
With support for the aptX HD Bluetooth transmission codec, the 1Mii B03Pro is capable of delivering sound quality at least equal to that of a CD, wirelessly.
Extended transmission distances
Using Bluetooth Class 1 technology and integrating two antennas, the B03Pro can reach transmission/reception distances of up to 30m (without obstacles).
ESS ES9018Q2C DAC
Widely recognized by audiophiles, the DAC ESS ES9018Q2C chip provides a rich and accurate reproduction. In particular, it provides a signal-to-noise ratio of 121dB while supporting PCM streams up to 32bit 384kHz.
Bluetooth 5.0
At the heart of the 1Mii B03Pro is a Qualcomm CSR8675 Bluetooth 5.0 chipset, a high-performance solution designed to ensure high-quality audio reproduction. It ensures clean and stable signal transmission and reception.
Additional connections
The B03Pro, in addition to its Bluetooth connectivity, offers a 3.5mm jack and Toslink Optics as inputs and outputs.
3 Modes of operation
Polyvalent, le 1Mii B03Pro peut être utilisé selon 3 modes différents, afin de s'adapter aux besoins de chacun : réception, émission et bypass.
Transmitter Mode
The 1Mii B03Pro can be used as a Bluetooth transmitter. In this mode, you can transmit an audio stream to an audio device, TV, AV receiver, headphones, speakers or any other source audio device with Bluetooth connectivity.
Receiver Mode
In receiver mode, the B03Pro can receive a Bluetooth audio stream from a connected device, such as a smartphone, tablet or computer.
Bypass Mode
Finally, the bypass mode directly connects an input to an output, disabling the receive and transmit functions.
Bypass mode allows the unit to be used in DAC (Digital to Analog Converter) mode, or ADC (Analog to Digital Converter) mode.
Product typeBluetooth Transmitter / Receiver
InputsBluetooth 5.0
1x Optical Toslink
1x Jack 3.5mm
OutputsBluetooth 5.0
1x Optical Toslink
1x Jack 3.5mm
Bluetooth chipQualcomm CSR8675
DAC ChipESS ES9018
Bluetooth version5.0
Supported Bluetooth profilesA2DP
AVRCP
Supported Bluetooth codecsSBC
AAC
aptX
aptX LL
aptX HD
Max transmission distanceObstacle-free: 30m
Package1x 1Mii B03Pro
1x USB-A to Micro USB cable
1x Jack 3.5mm to RCA cable
1x Jack 3.5mm cable
1x Optical cable
1x Power supply
InputJack 3.5mm
OutputOptical Toslink
OutputBluetooth
OutputJack 3.5mm
DAC / ADC ChipES9018Q2C
Supported Bluetooth codecsAAC
2 reviews
Efficace et simple
Récepteur efficace et très facile à installer. Je l’utilise uniquement en récepteur Bluetooth, en entrée d’un DAC Benchmark. Le résultat est excellent, aucun souci de connection, très bon rapport qualité prix pour ce récepteur qui passe inaperçu grâce à son petit format.
This review has been posted for 1MII LAVAUDIO B03PRO Receiver Transmitter Bluetooth 5.0 aptX HD CSR8675 ADC DAC ES9018
aucun problème d'installation et fonctionnement parfait
Bonne qualité apparente du produit par rapport au prix.
appairage sans problème (attention aux interférences possibles si un autre récepteur bluetooth est à proximité).
Portée sans problème de 15 m en intérieur (le max chez moi).
Très bonne qualité audio en ADC (je l'ai mis en sortie de chaîne et il permet l'écoute de vinyles de manière parfaite).
par rapport à mon sony WH1000xm4, c'est excellent même en SBC ou AAC, dommage qu'il n'assure pas le codec LDAC, mais cela reste théorique car la différence d'écoute dans d'autres configurations ne montre pas une supériorité réelle des codecs HD, impression confirmée par le revue des numériques.
en résumé une qualité/prix au top, je suis très satisfait de cet achat
The 1Mii B03Pro is an extremely versatile and high-performance Bluetooth transmitter and receiver at an affordable price. Its intelligent and...
